Go to Post We always have a party on Friday. It's called scouting. - Meredith Novak [more]
  #31   Spotlight this post!
Unread 29-01-2013, 11:43
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Re: Full Court Shooter!!! (Team 3528 UpNext)
Wouldn't Bluabot just keep ramming Redabot3 thereby hitting Redabot1? Bluabot isn't touching Redabot1 which is protected in the loading station, but Bluabot wouldn't be touching Redabot1 and they only need to disrupt the shooting enough to cause the discs to miss.
Originally Posted by 1075guy View Post
I saw another strategy mentioned in another thread, and I think you might see some of the powerhouses make use of it in Eliminations at shallow-ish regionals.
Redabot1 is a 60" tall high-accuracy full court shooter intended to shoot from the loading station.
Redabot2 is unknown
Redabot3 is a short, weak box bot as the 24th pick.
Bluabot is an 84" tall blocker bot.
Redabot1 goes to its loading station with Redabot3 glued to its bumper on the shooter exit face.
Bluabot can get no closer to the shooter of Redabot1 than the length of Redabot3's chassis. This should give enough distance for Redabot1's DISCs to rise above Bluabot's 84" block.
-T
  #32   Spotlight this post!
Unread 29-01-2013, 11:45
TheCrayButton's Avatar
TheCrayButton TheCrayButton is offline
FRC #3528
TheCrayButton has a spectacular aura aboutTheCrayButton has a spectacular aura about
Originally Posted by Woolly View Post
Right, but there still a few ways that could work out for them.
They could somehow be able to shoot full court with an incredibly light shooter.
They could have a collection system and just pick up the few missed shots from a robot like yours and put them in for that extra ~15 points.
Or, maybe they can't make it full court but they have a teammate they can feed to a la Bomb Squad on Einstein last year.
Which of those options, only the literal long shot allows for a self-sufficient robot which is very important for qualification matches. Thus, I think most teams will pass on being very tall.
That all defiantly could be done. I do agree with what you said. I think teams will pass on the idea of a tall bot too. The successful robots will be the ones that are small and are very maneuverable and fast. (like bomb squad).
  #33   Spotlight this post!
Unread 29-01-2013, 11:48
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Originally Posted by BrendanB View Post
Also as a word of caution, intentionally tipping an opponent ends very, very badly.
I hope we don't get the situations where teams playing defense against tall, tippy robots gets penalized because the other team failed to build a non-tippy robot. The refs need to look at the hit/pushing itself and not the end result.
  #34   Spotlight this post!
Unread 29-01-2013, 11:49
FRC #3528
6 weeks? Making a tall robot that doesn't tip can be done over lunch break at your regional. Lexan and some 1/16in box aluminum doesn't weigh very much.
Yes, this is true. But i won't look very good I am always weary of light robots that aren't build strong. It doesn't seem to me like a good idea to make your robot so darn light and flimsy.
Oh, yes I am aware. I am the lead driver, and I understand. That doesn't mean you can't accidentally knock them over
  #35   Spotlight this post!
Unread 29-01-2013, 11:52
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
It doesn't mean that while you're going to the pyramid to shoot from that protected zone that the tall, tippy robot won't try to block you, thus sealing their own fate.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
  #36   Spotlight this post!
Unread 29-01-2013, 13:25
Matthew Wang Matthew Wang is offline
Project Manager, Vice-President
FRC #3588 (The Talon)
Matthew Wang is an unknown quantity at this point
What kind of wheel are you using? And what diameter is it?
We are using a 12inch pneumatic wheel. We use 12inches because the frisbee contacts the wheel for a longer period of time. Also, compression is a big part of it. The wheel on ours is fairly flat. It doesn't have much air in it. Therefore, the tire cups the frisbee. We have found the happy medium when compressing the frisbee. If you have to much compression the frisbee will just spit out and not go to far because there is to much friction. If you don't have enough compression, the frisbee won't get that far.
Consistency is hard for sure. We made sure our platform on the curve was slick so the frisbees could slide easily. Also, our curved angle had to be touching the frisbee the same amount of time all the way around the wheel.
The hopper we are still working on. When the bottom frisbee is sitting there waiting to be shot, it is getting sucked in by the wind of the wheel. And when it does that, our frisbee's cup. Also, the whole platform is vibrating, so the frisbee's move a lot. To fix that, we are going to use a pneumatic piston that is vertical and extends on one side of the frisbee, when doing that, it keeps the frisbee in place. When we are ready to shoot, we will pull that piston down and then fire. It then repeats the process.
I hope that helps.
We are using an 8" pneumatic wheel. We have been able to shoot our frisbee far, but not consistently or accurately. Thanks a ton for the info.
Is there anyway for you to describe the amount of compression you're using better? I know it's hard to tell. We think we have found the right amount, but we could be wrong.
What material is your platform made of?
Competition Record
2011 Logomotion
  • Seattle Regional
  • St. Louis Championships
2012 Rebound Rumble
2013 Ultimate Ascent
Awards Record
2011 Logomotion
  • Rookie All-Star @ Seattle Regional
2012 Rebound Rumble
  • Team Spirit @ Seattle Regional
  #37   Spotlight this post!
Unread 29-01-2013, 14:32
FRC #3528
Right. A lot of people are using the 8" pneumatic wheel. I am assuming it is the Andy Mark one?
With the compression, what we did was we built the curved side all around the wheel to measure 11" exactly. This way, the frisbee barley touches the wheel when spinning. Then what we did was we started layering the curved side with material that we though would work. We used double sided sticky tape to mount the layers on the side. On the curves side we had these layers (in order). Metal-sticky tape-black pvc plastic-stick tape-tred.When you do that, it builds up the compression. We also let air out of the wheel a lot. So when the frisbee comes around, it cups the frisbee.
The platform is made out of black pvc plastic.
I hope that helps.
  #38   Spotlight this post!
Unread 29-01-2013, 14:58
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
How are you targeting in the video and how will you target during competition?
  #39   Spotlight this post!
Unread 30-01-2013, 00:24
FRC #3528
We didn't target in the video. We just set ourselves up at the right distance.
For the actually game, we will use a camera. I am not exactly sure how to explain all that, but i know we will use the camera to target our distance. Sorry :/
  #40   Spotlight this post!
Unread 30-01-2013, 11:52
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
I would say it is really hard to design a robot that is tall and that is not easily knocked over. Yes, i can be done, but in the 6 weeks we have to build, it is very difficult.
I believe there will be teams that are tall and can shoot well, but they will not make it very far because they can be blocked before they even get in their shooting position. Remember, the robot has to drive almost the whole length of the field to get to its shooting position.
Seriously? Daisy was 7" under that 60" max last year, and you could bounce them (like this). Ok, Daisy's awesome, but even we were 58" last year, and despite dukes-of-hazarding the barrier, we only ever tipped by being levered/pushed off the bridge (which isn't so much CG—and sometimes not even then). Very few of the good dunkers we pushed around ever even started to tip. Heck, forget how tall everyone had to be in 2007 and 2011: 2008 was throwing trackballs and even the tall guys did fine if they planned for it. The perimeter isn't that much smaller this year. Design around it (particularly in spec'ing your shooter); it's entirely doable. Dig back into history a bit a poke around--there's plenty of inspiration to see.
As for making a 60"-84" blocking robot--that's definitely a lunchtime job. Assuming you picked a well-built bot to begin with, getting them the extra 2-5' in an effective, durable, low-CG, and even good-looking fashion is entirely doable if you prepare. Check out some of the good nets from prior years. We've pulled off much crazier conversions in less time.
  #41   Spotlight this post!
Unread 30-01-2013, 17:15
Racer26 Racer26 is offline
They could, but if the full court shooter had opted for aiming at the 2 pt target (much easier given the angles), they have a 54"x21" opening they're firing into. you have to disrupt their shot a fair bit before you'll make them miss. You may make them 'miss' into a different goal than the one they were aiming for.
  #42   Spotlight this post!
Unread 31-01-2013, 00:01
FRC #3528
Right. Exactly. The 2 pt is way easier to score while being defended.
  #43   Spotlight this post!
Unread 31-01-2013, 10:02
Furthermore, if your teams' strategy is a full court shooter that essentially parks at the feeder station, which seems to be more valid this year than ever before, MAKE SURE YOU PRACTICE doing it while being defended. Slam a past robot into it while you're shooting, make sure that you can play through being defended, better still if the 'defenders' can violate the loading station no-touch rule, and your shots STILL succeed.
  #44   Spotlight this post!
Unread 31-01-2013, 11:25
FRC #3528
Yes sir! We plan on doing that. It is very important that we practice having a defender this year.
