Go to Post Computers have a nasty habit of doing exactly what you tell them to do instead of what you want them to do. - KenWittlief [more]
Unread 29-01-2013, 12:33
JCHS JCHS is offline
FRC #3301
JCHS is an unknown quantity at this point
Pneumatics Programming Help
Hi, I'm new to programming with Java. I'm using Netbeans command based robot. I currently have the drive and buttons working but I don't know how to do the pneumatics.
How do you program the compressor to start and stop on its own?
How do you tell the solenoids to fire?
I think I need a subsystem for pneumatics that controls all of this, and then specific commands to fire those solenoids. Any help would be much appreciated.
Unread 29-01-2013, 12:35
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Pneumatics Programming Help
Luckily you do not have to do anything for the compressor except create it and start it. We did this in RobotMap in the init() method.
To fire solenoids you do a set(true) and set(false) to then them on and off.
Unread 29-01-2013, 13:47
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
I was also new to java this year so I am glad to finally be on the opposite end of the question for once. All you need to do is put your compressor inside of whatever class you have extending iterative robot. Inside the robotInit method put in compressor.start(). Then leave the shutting off part to your pressure switch. Now make a subsystem for the piston you are using (for me I call ours ShootPiston). Inside the subsystem make two Solenoid objects (one for extend and one for retract). Make three methods (extend, retract, stop) and set the solenoid objects using their set method to true or false depending on what each one is doing. Then make commands to extend and retract and in there call each method respectively. If you need more help with this or if I wasn't clear let me know.
Unread 29-01-2013, 15:34
FRC #3301
Alright. I think I understand everything you are saying, but when I put compressor.start() in robotInit, it gave me an error like it can't find compressor. Why is this?
And I'm pretty sure I understand the solenoid part. Sounds simple enough. If you get bored, could you post me a link or a part of this code please just in case. Better safe than sorry.
Thanks again for your help.
Unread 29-01-2013, 16:10
FRC #3301
Never mind. I got it all figured out. Thanks again for your help. It really is pretty easy. I just didn't know where to put the compressor.
