Go to Post A few months from now I'll be walking to school and then I'll suddenly be attack by a rogue robot trying to feed me a golden ball or something wont I? - Marcel [more]
Unread 29-01-2013, 13:53
Patrick Levy Patrick Levy is offline
FRC #3202
Patrick Levy is an unknown quantity at this point
Shooter Track Material - grippy or slick?
Hi,
My team is going with a 1/4 turn shooter with an 8" wheel mounted directly to a CIM motor in the middle. We are currently trying to tweak it to get better distance. There is a debate going on whether we want the track that the frisbee rolls on to be grippy or slippery.
One side says that the wheel RPM is so much larger than the final velocity of the frisbee that it should be slick to allow for greater spinning of the frisbee. This will also cause less of a reduction in the RPM of the wheel as it accelerates the frisbee.
The other side says that to get the largest velocity the frisbee should grip the track without slipping so that the frisbee exits as the same velocity as the wheel is rotating.
What do you think?
Pat Levy
Team 3202
St. Paul, MN
Unread 29-01-2013, 13:55
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
Taking some personal time
Re: Shooter Track Material - grippy or slick?
Originally Posted by Patrick Levy View Post
Hi,
What do you think?
Pat Levy
Team 3202
St. Paul, MN
Prototype both and see what works better.
2012-2016 Wave Robotics Team 2826
Unread 29-01-2013, 14:10
rlowe61's Avatar
rlowe61 rlowe61 is offline
AKA: Roger
FRC #0624 (CRyptonite)
rlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant futurerlowe61 has a brilliant future
I've reviewed multiple videos of shooters, not all FIRST related. Also this year we've prototyped with different surfaces, wood, aluminum, foam, etc. Seems there are a lot of fine variables, between surfaces, both of wheels and walls, but also the amount of pressure placed on the disk. It's an 11" disk, but 11" of space doesn't give you the optimal velocity. Proto-type different things and find what works best for you, and remember 1/16 of an inch between the wheel and the wall can make a huge difference.
WHEELS: Solid, rubber, wrapped in foam, treaded....don't be afraid of trying different surfaces, it's almost fun to see the differences.
Good Luck
Roger
1986, Team Titanium, 2011 - 2012
624, CRyptonite, 2013 - ????
Unread 29-01-2013, 14:27
You've got that backwards. You want the rail to be grippy if you want greater spinning.
That's backwards too. If the frisbee grips the track without slipping, your exit speed will be limited to half the tangential speed of the wheel, but you'll get the greatest spin.
Unread 29-01-2013, 14:35
TheCrayButton's Avatar
TheCrayButton TheCrayButton is offline
FRC #3528
TheCrayButton has a spectacular aura aboutTheCrayButton has a spectacular aura about
We are using tred on the side of ours. You can see it in the video. We have found that grippy material works better.
VIDEO: http://www.youtube.com/watch?v=BzIke...er_profilepage
I hope that helps
Unread 29-01-2013, 14:44
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
No if the rail is slick the Frisbee will spin more and it's exit speed is lower. The slick rail allows the Frisbee to spin without moving down the track while the grippy rail causes it to advance at 1/2 the tangential speed of the shooter wheel (assuming no slip between the Frisbee and wheel). This is based not only on my gut feeling but our prototyping.
Unread 29-01-2013, 14:51
Hmm. Got an video? I'd like to see that.
Unread 29-01-2013, 14:54
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
No I'm with Ether, if the frisbee is against a slick surface it will slide along that surface and not get as much spin. If the surface is sticky it is forced to spin because it can't slide.
In all our testing the sticky surface always spins more and gets more distance than a slick surface.
Unread 29-01-2013, 14:59
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
This is going to require some hard data before I take it as fact.
Video, Chronograph, anything with solid numbers.
I'm only challenging this statement because it is opposite of what our analysis showed.
Exactly!
The spin causes the Frisbee to fly more stably and for a greater distance because of that stability. "Muzzle velocity" is not the only factor involved with Frisbee flight. Try hitting it with a tennis racket. You'll see very quickly the impact spin has on the flight of the disk.
Unread 29-01-2013, 15:24
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
I went to Ruckus (the skateboard shop) and bought us a thing of Grip Tape roughly... 1ft by 3 ft? for $7. It worked great for us
Team 3753 BulahBots
Unread 29-01-2013, 15:29
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Did your prototyping consider compression? When we say "grippy," we're really just referring to the friction between the disc and the rail.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We considered that, but are extremely concerned about what it will do to the longevity of the frisbees. 'Grinding' the end of them on the tape like that probably isn't a good idea. We're considering some thin die-rubber or something similar.
Unread 29-01-2013, 15:32
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
On our linear belt driven shooter, we found slick went further. I believe it is because we got higher velocity and less (but sufficient) spin as the disc slipped against the slick surface. We hope to gear up the belt speed and may need to try again. But then again, we used one other trick that is likely relevant, but that's a trade secret -- haven't seen it in any other shooter videos or descriptions.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 29-01-2013, 16:28
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
So coat your rail & bottom plate with your physics professor's frictionless goo. Will the Frisbee just sit there & spin?
Unread 29-01-2013, 16:38
AdamHeard's Avatar
Lead Mentor
No. As you stop playing with frisbees and instantly make billions selling the frictionless glue.
