Go to Post Don't worry about where you will be. Just consider youself lucky for being where you have been. - sanddrag [more]
Unread 29-01-2013, 13:56
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
Using the 12v-5v converter for powering custom circuits?
After pouring over the rules I have been unable to find anything referencing this leading me to believe that it is just fine, as the transformer is a 10A transformer and the Router draws only 785mA max
Unread 29-01-2013, 14:00
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Using the 12v-5v converter for powering custom circuits?
R44
The wireless bridge power feed must be supplied by the 12VDC-to-5VDC converter (P/N: CLL25-24S05) connected to the marked 12VDC supply terminals at the end of the PD Board (i.e. the terminals located between the indicator LEDs, and not the main WAGO connectors along the sides of the PD Board) shown in Figure 4?8. No other electrical load may be connected to these terminals.
This seems ambiguous to me. I would post to the Q&A.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 29-01-2013, 14:02
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
That's fine, if you mean that you're going to use a second converter for this circuit. R44 says you must use a converter for powering the radio, and you can't connect anything else to it.
R44:
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 29-01-2013, 14:08
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I don't think it's all that ambiguous - it clearly states "No other electrical load may be connected to these terminals." Whether the electrical load comes before or after the converter doesn't matter - it's still an electrical load that is connected to that output on the PDB.
Also, while the converter may be capable of handling higher loads, per the PDB documentation, that port will only supply 2A:
12V/2A boost supply with on-board 2A PTC for over-current protection (typically for powering a
WiFi adapter, the boost supply tracks battery voltage when the battery is fully charged and
greater than 12V)
2016: Lake Superior WFFA
Unread 29-01-2013, 15:29
If I were asked for clarification on this issue, I would disallow it.
There is a good bit of margin in the design of that boost regulator, but not enough to justify the added risk of allowing arbitrary extra loads. Browning out that supply will likely decide a match against you.
However, it is fine for non-competition use.
Unread 29-01-2013, 15:32
AKA: Mark Omo
FRC #1703 (RATS)
Thank you all I focused on the wrong set of rules
