Go to Post We're college students. We appreciate free. - Billfred [more]
Unread 29-01-2013, 17:21
Rambunction Rambunction is offline
FRC #4330
Rambunction is an unknown quantity at this point
Cannot create an RGBImage instance
Right now our robot doesn't have a camera on it so we're trying to run a local program with the wpilibj libraries. We're loading an image taken from last year onto the program but we can't get it to do anything. We simplified the code down to just the declaration:
new RGBImage();
Which results in this error:
Exception in thread "main" java.lang.ExceptionInInitializerError
	at edu.wpi.first.wpilibj.image.Image.<init>(Image.java:24)
	at edu.wpi.first.wpilibj.image.ColorImage.<init>(ColorImage.java:16)
	at edu.wpi.first.wpilibj.image.RGBImage.<init>(RGBImage.java:20)
	at localapp.Optical.main(Optical.java:33)
Caused by: java.lang.ClassCastException: java.lang.String cannot be cast to com.sun.squawk.Address
	at com.sun.squawk.NativeUnsafe.getInt(NativeUnsafe.java:340)
	at com.sun.squawk.NativeUnsafe.getUWord(NativeUnsafe.java:360)
	at com.sun.squawk.NativeUnsafe.getObject(NativeUnsafe.java:404)
	at com.sun.squawk.NativeUnsafe.getAddress(NativeUnsafe.java:414)
	at com.sun.squawk.GC.getKlass(GC.java:1077)
	at com.sun.cldc.jna.Pointer.createStringBuffer(Pointer.java:402)
	at com.sun.cldc.jna.TaskExecutor.<init>(TaskExecutor.java:105)
	at com.sun.cldc.jna.TaskExecutor.<init>(TaskExecutor.java:116)
	at edu.wpi.first.wpilibj.image.NIVision.<clinit>(NIVision.java:29)
	... 4 more
Java Result: 1
What are we doing wrong here?
Unread 30-01-2013, 16:34
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Re: Cannot create an RGBImage instance
This seems to be a problem with the squawk VM not being able to work with the hardware. If I understand your post correctly, you're trying to run this on a computer. The exception says that a string cannot be cast to an address, and it seems that an address has to do with lower level communication to peripherals and some of the primitive data types. The squawk VM is not designed to be run on the computer, so when java tries to allocate some block of memory for your empty image and it uses the address class to access the memory, it fails to do so. Ifyou want to experiment with image pprocessing, you can use vision assistant.
