#16
Re: Power Distribution Board visibility for inspection
As Grim Tuesday noted, as an inspector I would be unhappy with that, but eventually I would pass it. Good luck changing out a wire or breaker in a hurry!
#17
But chiming in as a team member...why would you do that to yourselves? I can almost guarantee that you're going to regret that location during some point in the season. |
#18
Do you guys think it would be fine to mount the PDB on the underside of the robot? When the robot is flipped it would be easy to see for inspection.
#19
Legal? Yes. Smart? No. As your robot bounces and hit things, the breakers could fall out if its mounted upside down.
#20
Also, ground clearance might be an issue depending on your setup. I'd hate to see you smash the PDB into the bump around the pyramids (or snag wiring on a frisbee you've run over). ![]() |
