Go to Post These two options can both be used effectively to create a wonderful experience for the students, but limiting them to one area is like taking a globe, slicing it in half, and saying, "You can only explore this half." - Alex Golec [more]
Unread 24-01-2013, 20:41
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
Can't find the cRio image when using imaging tool
Hi all!
I'm a non-technical mentor trying to help out our technical folks by asking here for additional infomation.
We have an 8 slot cRio and we're using Java. The cRio is connected to the laptop with ethernet with a switch in between the two.
They've done the NI FRC Tools Installation.
When we read the instructions here:http://wpilib.screenstepslive.com/s/...onent-overview and we get to the section that's titled FRC 2013 Imaging Tool, there's nothing in the Format Controller Select Image box.
Any suggestions as to what's going on?
Thank you!
Trying to Help
Team 1729
Unread 24-01-2013, 20:52
JM033's Avatar
JM033 JM033 is offline
AKA: J
FRC #0240 (Tempest)
JM033 is an unknown quantity at this point
Re: Can't find the cRio image when using imaging tool
We just Re-imaged the crio so it's right in my memory..lol Before starting make sure you run the NI-Update Service that comes installed with labview. Then just follow the directions carefully on this website. http://wpilib.screenstepslive.com/s/...ging-your-crio
It took us about 2 hours to re-image ours cause we had problems connecting, just make sure ip address settings are good and you have everything updated.
Unread 24-01-2013, 20:55
Thanks for the quick reply! My techical mentor asks: will this work for Java?
thanks again!
Unread 24-01-2013, 20:56
From: http://wpilib.screenstepslive.com/s/...manual-id=8559
Verify that the image listed is FRC_2013_v47.zip (Note: The picture above shows v46). If there is no image listed in this box or the image is not v47, make sure you have installed the latest update for your programming language.
Unread 24-01-2013, 20:57
If the image is missing, then you probably haven't installed the language specific Updates. That's where the images come from.
Unread 24-01-2013, 21:04
Thanks folks!
We'll keep working on it.
Unread 27-01-2013, 11:21
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Always use a cable and don't try to image over wireless. Use either a cross over cable from the pc to the crio or use two of any kind of cables with the dlink in between.
Turn off any wireless adapters.
Make sure there is only one ip address set under the network adapter.
If the computer was used last year, make sure you are running the 2013 version of the imaging too.
Be sure and enter the team number.
Brian K
Team 1225 Robotics Mentor
Unread 29-01-2013, 17:08
Negative 9 Negative 9 is offline
FRC #0611
Negative 9 is an unknown quantity at this point
The image is actually packed with Netbeans FRC plugins this year. When you install the plugins on your classmate (or whichever PC you're using to image the cRIO) the v47 image will appear in the dialog box on the 2013 imaging tool. Our team drove themselves crazy looking for the standalone zip file too.
Unread 29-01-2013, 17:57
Thanks for confirming that Negative 9!
Trying to Help
www.Team1729.org
