Go to Post "We used to shut the robot up in a box and send it away from home. Now we just suffocate it." - GaryVoshol [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 29-01-2013, 18:01
nickhilgupta's Avatar
nickhilgupta nickhilgupta is offline
FRC #4674
nickhilgupta is an unknown quantity at this point
Centered Hole on frame
Is there a reason there is one hole drilled off center on the channel aluminum for the frame.
We mounted our center wheels on that hole, and it raises our front wheels off of the ground. In turn not letting us have all 6 wheels on the ground at the same time. Can we modify the frame so that all wheels will be flat on the bottom? Or is there a better solution?
Thanks
Unread 29-01-2013, 18:07
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Centered Hole on frame
Thanks
The center hole is purposefully lowered to create the condition you're seeing. You don't want all six wheels touching the ground at once, as it may make it difficult for your robot to turn in place. The kitbot provides a frame to you implementing what are commonly considered to be best practices for FIRST robot design.
--Madison--
...down at the Ozdust!
Unread 29-01-2013, 18:23
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
+1, The six and eight wheels drop center drives are the gold standard in FIRST, in all their iterations and off shoots, such as WCD.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 29-01-2013, 18:27
Generator of Entropy
FRC #2973 (The Mad Rockers)
To understand this concept, draw a top view of your robot and consider how it turns about the center. The 2 middle wheels move tangent to the circle in their direction of rotation, while the 4 outboard wheels move at an angle so they tend to drag sideways (and you'll see robots "jumping" as they turn to overcome this). The idea is to let the center wheels hold most of the weight while turning, so along with this you want to try to have your center of mass as close to the center of the robot (that hole) as possible.
Unread 29-01-2013, 22:38
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
We use omni-wheels on the corners, so we don't have to worry about the corner wheels dragging (as much ).
This is our 4th year doing that (even though we're only using 4 wheels this year) and we love the performance.
Unread 29-01-2013, 23:19
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Flip your c-channel around. The middle wheel should be lowered, not raised so you can have a smaller wheel base.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 29-01-2013, 23:21
No. They have it correct, as is. You mis-read.
Unread 29-01-2013, 23:22
Gregor's Avatar
This is why you don't post when tired. Good catch, my bad. Continue rocking on.
<Since 2011
