Thread Tools |
Rating:
Display Modes |
Re: 3753 shooter. 12 points in 2 seconds
Today we shot 4 frisbees in 1 second. Here's the video.
Your shooter looks amazing! Would you mind explaining it in further detail? How can you shoot so rapidly? What kind of motor/gearbox setups are you using? How much squeeze do you put on the frisbee? How much room is in between your wheels?
This looks like an awesome design. I can't wait to see 3753 in action this year. Keep up the good work! |
We actually didn't do anything complicated, it just all worked REALLY well! Our shooter is pretty simple: Two CIM motors with Pneumatic wheels attached, and a Window Motor with a small piece of L bracket stuff attached to the plastic black wheel thing. The window motor and its attached arm push frisbees into the two wheels, which then shoot the frisbees. We put stoppers (screw) in the way of the window motor's arm so it could only turn so much either way. If you look at the first video in my signature, you'll see some pictures of the shooter before we put our feeder on top. As for shooting fast, I programmed the window motor like this: Code:
When button 3 is pressed 1) Set the window motor's output to -1 (forward. We mounted the window motor upside down, so the (-) is forward and vice versa) 2) Wait x miliseconds 3) Set the window motor's output to 1 4) Wait x miliseconds 5) Set the window motor's output to 0, ending orders to the arm (so that it doesnt CONSTANTLY try to push against our stoppers and mess up the motor) The way the code is set up, hitting the button ONCE will make the action run once -- it doesn't matter if you let go of the button before the sequence ends, it will finish the whole order. If you hold the button down for longer than the duration of one sequence, it'll loop repeatedly. Since our stoppers are FAIRLY close together, the arm only turns about 70 degrees, meaning it doesn't take long to go from one stopper to the other, so it can go forward and back in a fraction of a second. Looping it gave us the results you saw Hope this helps! Now we just need to decide on a climber (and a climbing destination) ![]() |
Since we detailed our shooter so much, I might as well share what I learned yesterday:
The thing that holds the frisbees in place to shoot (for us, that blue/orange home depot bucket) MUST be ABSOLUTELY sturdy and immovable. Ours has yet to be 100% attached but we had it roughly in the right spot and could shoot correctly for a while. However the last day or two we're only able to shoot about 1 in 6 shots correctly. So before you practice shooting or autonomous, be absolutely positively sure that the hopper (I think that's what it's called?) does not hinder your shooting. |
#7
Tag on a level one pyramid climb and you'll be doing really well at most regional events. Best of luck at the competitions. |
