Go to Post Mastering simple skills can be a complex challenge. - Petey [more]
Unread 29-01-2013, 20:29
twiegner twiegner is offline
FRC #2495
twiegner is on a distinguished road
Double Action/Spring Return Pneumatic Actuators
My team is looking to use a Spring Return piston to possibly eliminate the need of an onboard compressor (we only need 1, 6" stroke actuator). We are looking to know 2 things
1: Will spring return pistons only use the equivalent of 1 burst or is there a drawback to these actuators?
2: Where would we get one of these actuators, our normal supplier is Bimba but I can't seem to find larger spring return actuators. I found mini actuators but they only have a max of around a 2" stroke and we need 6".
Unread 29-01-2013, 20:33
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Double Action/Spring Return Pneumatic Actuators
The primary drawback of spring return cylinders is reduced force for a given bore size, since the pressure must overcome the spring while extending, and must use this same, relatively weak spring for the return stroke. Depending on your application, this may be a non-issue.
Unread 29-01-2013, 20:38
FRC #2495
Ah yes, were just pushing a frisbee so that shouldn't be to much of a problem.
Unread 29-01-2013, 21:06
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
What you're talking about is a single acting cylinder. Unfortunately this type is typically only available in short strokes. The internal spring needs to be approx. 2X the stroke length, so it isn't practical for longer cylinders.
You could simulate a single acting cylinder by leaving the air fitting off the nose end of a double-acting cylinder and using an external spring or elastic to retract your piston. Be careful not to side-load the piston rod, especially when fully extended. That's when it's most vulnerable to damage.
Unread 29-01-2013, 21:20
FRC #2495
Hmmm... at the workshop we went to at kickoff, the team had a nice long spring return actuator that went at least 6" if not 8", they mentioned where they got their pneumatics but I cannot remember at the moment. As for an external spring, at that point it may be more trouble than its worth, if anyone does know of a place to buy a 6" stroke spring return pneumatic actuator that would be fantastic, otherwise we may use a rack & pinion setup with a limit switch to do auto return and not use pneumatics or just do some precise calculations to see how much air we would need stored to shoot and return a piston as many times as we think is reasonable.
Unread 29-01-2013, 21:25
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
or you could have another reg in the system to run at a lower pressure for the return stroke.
My Instructables
Unread 29-01-2013, 21:46
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
McMaster Carr carries single acting spring return cylinders to 12"
http://www.mcmaster.com/#standard-air-cylinders/=l94zkd
Unread 30-01-2013, 01:28
FRC #2495
This is exactly what we needed, thank you so much. Not quite sure why we didn't check McMaster, I guess we don't use them much for pneumatics. Though I do have to say that if this doesn't work we are going to but some serious thought into 1 of 4 choices. 1. Carrying more air tanks 2. Carrying a compressor 3. Alex's suggestion of adding another regulator or 4. Ditching pneumatics for a rack and pinion.
Unread 30-01-2013, 13:40
AKA: Kevin Thorp
Whoops... I commited the CD sin of posting an answer without double checking my info. Thanks George!
Unread 30-01-2013, 14:38
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
While a rack and pinion system is certainly a way to achieve linear motion given a rotational input, there are other viable solutions as well. If you want to move away from pneumatics for this application, perhaps you should also consider a crank, cam and follower, or whether you even need linear motion at all.
