Go to Post Winning just makes your ego smile. - MooreteP [more]
Unread 28-01-2013, 13:14
JM033's Avatar
JM033 JM033 is offline
AKA: J
FRC #0240 (Tempest)
JM033 is an unknown quantity at this point
Re: Walkthrough on how to do offboard image processing!
So I do the image processing on the dashboard and I do a UDP send of my target info results from the dashboard to the robot (crio). From their I make a UDP receive in my robot code from the dashboard. Correct?
Unread 28-01-2013, 14:14
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
what ports are people using for sending the data back from the DS to the robot? Doesn't the FMS only pass data destined for a limited selection of ports?
According to the FMS White Paper:
The ports that the teams are able to access on the playing field are as follows:
  • TCP 1180: This port is typically used for camera data from the robot to the DS when the camera is connected to port 2 on the 8-slot cRIO. This port is bidirectional on the field.
  • TCP 1735: SmartDashboard, bidirectional
  • UDP 1130: Dashboard-to-Robot control data, directional
  • UDP 1140: Robot-to-Dashboard status data, directional
  • HTTP 80: Camera connected via switch on the robot, bidirectional
  • HTTP 443: Camera connected via switch on the robot, bidirectional
Unread 28-01-2013, 16:43
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Originally Posted by muaddib42 View Post
This is probably such a simple answer, but how do I place the VI script for image processing on the dashboard? I created the script using NI Vision Assistant, but I don't know how to place it in the modified Dashboard project.
Thank you
NI explains it better than I could - "You also can add a VI to the project by selecting the VI icon in the upper right corner of a front panel or block diagram window and dragging the icon to the target. When you add a VI to the project, LabVIEW automatically adds its entire hierarchy to the Project Explorer window under Dependencies."
Basically click and drag the icon in the upper right hand corner of the block diagram of the VI you're trying to import, into the dashboard project.
That's exactly right. I'll be updating this for smartdashboard today.
As far as concerns about port numbers go, fovea you're right that only a few ports are allowed during comp. We used 1130, since it's open for sending data from Dashboard to Robot which is exactly what we're doing.
Unread 28-01-2013, 19:50
ohrly?'s Avatar
ohrly? ohrly? is offline
Griffin Alum
AKA: Colin Poler
FRC #1884 (The Griffins)
ohrly? is an unknown quantity at this point
We're using a raspberry pi as well (python+opencv after many years of disappointment with NIVision), and I don't know if we should use network tables or TCP? Recommendations?
Also, I don't know either protocol, so is it worth it to learn the protocols or just use someone else's code?
Unread 28-01-2013, 20:35
violinuxer violinuxer is offline
FRC #2523
violinuxer is an unknown quantity at this point
You'll have the easiest time doing your vision processing in either C or Labview.
Have you guys tried using WPIJavaCV/SmartDashboard? We use it to do image processing and then use NetworkTables to send values back to the robot. I think you may be able to use pure OpenCV functions if you want (via JavaCV) for plenty of power.
Sorry if I'm being redundant...
violinuxer
May the source be with you!!
(Linux FTW!)
Unread 28-01-2013, 20:59
AKA: JD Russo
Now that the documentation for NetworkTables has been posted, I'd use that, but you'd have to find a way to use it with Python. Maybe a C middleman would be the easiest way, so you don't have to reimplement NetworkTables in Python. If you don't feel like figuring that out, then I'd stick with either TCP or UDP.
I'll be updating the guide soon as I have the time with more information on using NetworkTables.
violinuxer
It's certainly possible, I haven't looked into it but I'd love if you guys would share your work. I chose the C/Labview route because it let me use the vision assistant.
Unread 29-01-2013, 09:30
FRC #2523
Here is how we did it last year:
Smart dashboard comes with the wrapper to OpenCV. You install SmartDashboard via the installer (available at firstforge.wpi.edu) and add the included library jar files (there are tutorial pdfs available on the web) into a pure java Netbeans project. You then extend WPICameraExtension in which you can process an image, do thresholding, polygon detection, etc. etc. Any calculated values are then sent back to the robot via NetworkTables.
Below is our image processing code from last year. Note the synchronized block, that's how we sent the values back to the robot.
import edu.wpi.first.smartdashboard.camera.WPICameraExtension;
import edu.wpi.first.smartdashboard.properties.DoubleProperty;
import edu.wpi.first.smartdashboard.properties.IntegerProperty;
import edu.wpi.first.wpijavacv.*;
import edu.wpi.first.wpilibj.networking.NetworkTable;
import java.util.ArrayList;
public class VisionProcessing extends WPICameraExtension {
     public static final String NAME = "Camera Target Tracker";
     public final IntegerProperty threshold = new IntegerProperty(this, "Threshold", 180);
     public final DoubleProperty contourPolygonApproximationPct = new DoubleProperty(this, "Polygon Approximation %", 45);
     NetworkTable table = NetworkTable.getTable("camera");
        WPIColor targetColor = new WPIColor (0,255,0);
        WPIColor contourColor = new WPIColor (17,133,133);
        @Override
        public WPIImage processImage(WPIColorImage rawImage) {
            WPIBinaryImage blue = rawImage.getBlueChannel().getThreshold(threshold.getValue());
            WPIBinaryImage green = rawImage.getGreenChannel().getThreshold(threshold.getValue());
            WPIBinaryImage red = rawImage.getRedChannel().getThreshold(threshold.getValue());
            // Does the thresholding;
            WPIBinaryImage colorsCombined = blue.getAnd(red).getAnd(green);
            //Mixes the paint;
            colorsCombined.erode(2);
            colorsCombined.dilate(6);
            //Gets rid of small stuff and fills holes;
            WPIContour[] contours = colorsCombined.findContours();
            rawImage.drawContours(contours, contourColor, 3);
            ArrayList<WPIPolygon> polygons = new ArrayList<WPIPolygon>();
            for (WPIContour c : contours) {
                double ratio = ((double)c.getHeight())/ ((double)c.getWidth());
                //if (ratio < 1.5 && ratio > .75)
                if (1==1) {
                    polygons.add(c.approxPolygon(contourPolygonApproximationPct.getValue()));
                    //Makes polygons around edges;
            ArrayList<WPIPolygon> possiblePolygons = new ArrayList<WPIPolygon>();
            for (WPIPolygon p : polygons) {
                if (p.isConvex() && p.getNumVertices() == 4) {
                    possiblePolygons.add(p);
                } else {
                    rawImage.drawPolygon(p, WPIColor.MAGENTA, 1);
            WPIPolygon square = null;
            int squareArea = 0;
            double centerX = 0;
            double heightRatio = 0;
            for (WPIPolygon p : possiblePolygons) {
                rawImage.drawPolygon(p, WPIColor.BLUE, 5);
                for (WPIPolygon q : possiblePolygons) {
                    if (p == q)
                        continue;
                    int pCenterX = (p.getX() + (p.getWidth()/2));
                    int qCenterX = (q.getX() + (q.getWidth()/2));
                    int pCenterY = (p.getY() + (p.getHeight()/2));
                    int qCenterY = (q.getY() + (q.getHeight()/2));
//                    rawImage.drawPoint(new WPIPoint(pCenterX, pCenterY), targetColor, 5);
//                    rawImage.drawPoint(new WPIPoint(qCenterX, qCenterY), targetColor, 5);
                    if (Math.abs(pCenterX - qCenterX) < 20 && Math.abs(pCenterY - qCenterY) < 20) {
                         int pArea = Math.abs(p.getArea());
                         int qArea = Math.abs(q.getArea());
                         if (square != null) {
                             if (square.getY() < p.getY())
                                 continue;
                                 // if we already have a square, and it is lower, doesn't add anything
                         if (pArea>qArea) {
                             square = p;
                             squareArea = pArea;
                             centerX = (double)pCenterX/rawImage.getWidth()-.5;
                         } else {
                             square = q;
                             squareArea = qArea;
                             centerX = (double)qCenterX/rawImage.getWidth()-.5;
                         WPIPoint [] v = square.getPoints();
                         int x1 = Math.abs(v[1].getX() - v[0].getX());
                         int y1 = Math.abs(v[1].getY() - v[0].getY());
                         int y2 = Math.abs(v[2].getY() - v[1].getY());
                         int y3 = Math.abs(v[3].getY() - v[2].getY());
                         int y4 = Math.abs(v[0].getY() - v[3].getY());
                         if (y1 > x1) { // first segment isvertical
                             heightRatio = (double)y1 / y3;
                         } else {
                             heightRatio = (double)y2 / y4;
                         break;
                int sCenterX = (square.getX() + (square.getWidth()/2));
                int sCenterY = (square.getY() + (square.getHeight()/2));
                rawImage.drawPoint(new WPIPoint(sCenterX, sCenterY), targetColor, 5);
            synchronized (table) {
                table.beginTransaction();
                if (square != null)
                    double distance = (1564.4/Math.sqrt(squareArea) - 0.5719) * 12;
                    table.putBoolean("found", true);
                    table.putDouble("area", squareArea);
                    table.putDouble("distance", distance);
                    table.putDouble("xoffset", -centerX);
                    table.putDouble("heightratio", heightRatio);
                else
                    table.putBoolean("found", false);
                table.endTransaction();
            return rawImage;
Anyhow, I'll see if I can find the docs on getting WPIJavaCV set up and will post later.
violinuxer
(Linux FTW!)
Unread 29-01-2013, 15:31
JM033's Avatar
AKA: J
FRC #0240 (Tempest)
Kinda like this rambo?
https://www.dropbox.com/s/it4kfwq2ny6mew5/Vision.png
Unread 29-01-2013, 15:32
JM033's Avatar
AKA: J
FRC #0240 (Tempest)
Is that correct?
Unread 29-01-2013, 16:42
AKA: JD Russo
Looks good to me. Let me know if something breaks horribly. As an aside, UDP doesn't work in Java, for any teams considering trying.
I did it slightly differently by putting the UDP send inside the Dashboard loop, and the socket open and close outside of the normal running loop. I don't know if it'd have problems with you opening and closing the port rapidly like yours might, if you get errors that it can't bind because address is already in use that's likely it.
This is my new implementation of the viToCRIO VI, redone to use networktables. It posts all the x,y coordinates of each target, and the range, to fields in the NetworkTable.
In the robot code, I use this command to handle sorting the targets and storing top, bottom, left, and right targets. Now, it'll also pull the values from the networktable instead of using the TCP connection. (See lines 113-139)
Line 103 in this, our main robot class, sets up the NetworkTable in case you need a Java example.
Unread 29-01-2013, 19:11
JM033's Avatar
AKA: J
FRC #0240 (Tempest)
can someone upload their dashboard code with the vision tracking and udp stuff, I'm having a lot of trouble trying to run it :*(
Unread 29-01-2013, 19:36
AKA: JD Russo
Not at the lab right now so I can't, sorry. What trouble are you having?
Unread 29-01-2013, 19:43
JM033's Avatar
AKA: J
FRC #0240 (Tempest)
So I deleted dashboard main from a new dashboard project, and replaced it with the vision processing vi from rectangular target - 2013 sample code. Put UDP stuff in it, and It opens a bunch of random windows of my code when I load driverstation, and asks me too find "LVODE.dll" which I did. Then I don't have any camera image. Too much
Don't think I'm building it right
Unread 29-01-2013, 21:49
AKA: JD Russo
You don't want to delete the entire Dashboard, you want to drop the vision processing code inside of the current one. Check out the screenshots of my VI in the OP.
Unread 29-01-2013, 22:01
JM033's Avatar
AKA: J
FRC #0240 (Tempest)
As in drop the vision processing subvi inside the dashboard main? Or just add it to the project? You should just save me my stupidity and upload your dashboard so I have a better understanding? I only got your screenshot of network table which seems pretty complicated btw, but I want to use UDP..other screenies in java so I have no clue.
Sorry, total noob here -__-
