Go to Post Oh, you mean the refs. The only hand signal I've seen the judges use is the hi-five. - RoboMom [more]
Unread 26-01-2013, 21:03
arithehun arithehun is offline
AKA: Ari Falkner
FRC #3024
arithehun is an unknown quantity at this point
Ramping Motors?
Does anyone have any experience with ramping motors in a command based system? I tried adding a for loop to a subsystem method but then I couldn't drive the robot asynchronously. So I tried adding a command to make the subsystem drive at a variable speed and then creating a command group that uses a for-loop to add a series of that command, each with an increasing parameter. This worked asynchronously, but I needed to be able to change the variables continually throughout the program, not have them be statically set like commands do (if you use them correctly, of course). I could. I know these are both terrible ways to accomplish this besides the caveats I mentioned (the second one particularly bad), but I was desperate.
In short, is there a better way to do this by making the variables both adjustable via the dashboard (instead of being initially set when the robot turns on) AND make this loop operate asynchronously?
Unread 26-01-2013, 22:37
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Ramping Motors?
In execute, try something along the lines of:
if (currentVoltage < targetVoltage)
currentVoltage += 0.01
else if (currentVoltage > targetVoltage)
currentVoltage -= 0.01
This will bump your voltage closer to your target voltage each iterative loop.
Of course you'll want to clean it up, but this should give you a general idea.
Do not use loops inside your command executes. They are already looped for you each during iteration. Unlike the SimpleRobot template, you cannot loop inside your command executes for a long period of time. Your execute methods need to run as quickly as possible, so any other parallel commands can be run immediately after. If you loop, you will stall the rest of your code, thus losing the ability to run things asynchronously.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 27-01-2013, 17:04
Azrathud's Avatar
Azrathud Azrathud is offline
Computer Nerd
AKA: Bryce Guinta
FRC #2945 (BANG)
Azrathud is on a distinguished road
Re: Ramping Motors?
Instead of trying to do what you want programatically, you might want to use built-in options for your motor controller.
If you are using jaguars, they have ramping modes built in(but disabled by default). To enable voltage ramping, you need to change some jumpers.(see in the attached manual p.12) You can even change the rate of ramping using the serial interface and some NI software.
Checkout page 11 of the attached manual to see if this is what you want. Look at coast/break jumper and the automatic ramp mode.
Unread 27-01-2013, 21:37
AKA: Ari Falkner
FRC #3024
Re: Ramping Motors?
Of course there's a jumper solution. Why didn't I think of it?
Also, the guide on commands was really bad. I'll take it into account that it loops repeatedly. Thanks to you both!
Unread 27-01-2013, 22:59
Re: Ramping Motors?
It depends on what you want the ramping to do for you.
In PWM mode, the ramp is 0.06 seconds from neutral to full throttle.
That's enough to reduce the occurrence of Jag overcurrent trips.
But if you're trying to change the feel of the driver interface it's probably not going to help.
Unread 28-01-2013, 13:30
Azrathud's Avatar
Computer Nerd
AKA: Bryce Guinta
FRC #2945 (BANG)
Re: Ramping Motors?
I thought you could change values using a serial interface(just a one time connection) using the BDC-COMM software and then have it work for PWM.
Unread 28-01-2013, 14:13
AKA: Ari Falkner
FRC #3024
Re: Ramping Motors?
Oh, sweet, I just downloaded the software. I am using PWM, so that's really helpful.
Unread 28-01-2013, 15:14
Re: Ramping Motors?
If that's true, it's good to know.
Q8 & Q9 in the FAQ seem to be saying that the factory "preset value" cannot be changed, and will be used every time the Jag is power cycled. Could someone who has actually done it please confirm?
ID:	13700  Click image for larger version
Unread 28-01-2013, 17:08
AKA: Ari Falkner
FRC #3024
Re: Ramping Motors?
It also mentions that it only resets the ramp rate if the automatic mode is enabled. You can disable the mode, it says in your second thumbnail.
Unread 28-01-2013, 17:18
Re: Ramping Motors?
If you disable it, it doesn't function in PWM mode. So it's not clear what point you are making. e.g. I have a car with a dead battery. It works fine unless I try to start it.
Unread 28-01-2013, 18:26
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Re: Ramping Motors?
No, you can't save a ramp rate and have it stick after a power cycle. The only configuration parameter that is saved in flash (immune to a power cycle) is the Jaguar ID.
The idea behind the Automatic Ramp Mode was to give teams a quick way to prevent high current spikes without having to write code or hook up the CAN/Serial interface.
If you need the ability to tweak your ramp rate, you either need to use CAN/Serial the whole time or write a ramp into your PWM code.
-David
Unread 28-01-2013, 20:20
AKA: Ari Falkner
FRC #3024
Re: Ramping Motors?
PWM is stupid, I'm switching to CAN. Unfortunately, I didn't request CAN when I ordered, so now I have to buy the RS232-RJ11 and RJ11-RJ11 cables. Oh well...
Unread 29-01-2013, 22:05
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Re: Ramping Motors?
If you don't want to use CAN and you still want ramping, you can modify the source file for the Jaguar class to just average out speeds over the last 20 ms or so before setting the output speed.
Unread 11-02-2013, 00:13
AKA: Ari Falkner
FRC #3024
Re: Ramping Motors?
Yeah, but now that I read up on it, I may want to use the jaguar PID modules too to keep my own code as clean as possible.
