Go to Post It's been said before--sports are fine and good, as long as you've got your priorities in the right order for you. - Billfred [more]
Unread 15-01-2003, 18:50
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Yeah, somebody else just told me about that last night. I'm now hitting my head against my desk repeatedly for adding a call to removeSpaces withing the makeCmdIf function. Stupid, stupid, stupid, stupid, stupid...
Look for yet another new version by tomorrow night.
Unread 16-01-2003, 22:01
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Modulus operator?
Does RoboEmu support the modulus operator (//)? I have a statement:
if (CCDataIn <> ((PrevDataIn + 2) // 256)) then
and it give the error "Error: Variable /256 does not exist. Can't get value. While processing If @((CCDATAIN;((PREVDATAIN+2)//256)))"
Thanks for the tool, it's been a big help while we're sitting around waiting for a robot to play with.
Mike
Unread 16-01-2003, 22:03
Ooops. Kinda forgot that one. Look for it in 1.10 as it definately should be there.
Unread 21-01-2003, 07:37
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Does the RoboEMU support delta_t?
Unread 21-01-2003, 09:09
No. It wouldn't really work, either, due to the speed differences between computers. If I figure out a way of making it work, I might add it. Anyway, 1.10 is done now, so grab that.
Unread 21-01-2003, 15:07
rust710's Avatar
I have the 1.10 but I posted in the wrong forum. Thanks for the response. What will the program do when it incounters delta_t?
Unread 21-01-2003, 17:08
I honestly don't know. It shouldn't crash, but it may return some insane number. Let me know if you find out.
Unread 21-01-2003, 17:22
rust710's Avatar
Well I tried it and it just returns a 0. Which actually is fine. The Stamp will return a 0 if the code is executed in 26ms or less. So my code works fine. delta_t has to be declared and is in the serin so it acts like a varible not set.
One thing that you program doesn't support is toggle. For example toggle 15 changes the state for one of the relay lights. Really same as out15 = ~(out15).
I really like your program. I have been using it even when I have a robot controller because it is easier to setup.
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
Broken PBASIC 2.5 Complier? Mike Yan Programming 12 01-02-2003 09:11
PBASIC 2.5 Questions Noah Programming 6 10-01-2003 19:26
PBASIC 2.5 answer from Parallax JasonS Programming 6 07-01-2003 19:21
