Go to Post Are yellow cards still being given out like AOL demo CDs in the late 90s? - Billfred [more]
Unread 29-01-2013, 20:08
wdburk3160 wdburk3160 is offline
AKA: William Burk
FRC #3160 (F.R.O.G.)
wdburk3160 is an unknown quantity at this point
Integrating Dashboard Project
We are going to use two camera feeds this year, so we need to customize the Dashboard a little bit. After making a custom Dashboard project, how do you integrate it into your crio project?
Unread 29-01-2013, 20:54
Re: Integrating Dashboard Project
There isn't much integration required, since the Dashboard is a standalone application.
If you're just looking at camera video, then you just duplicate the camera feeds.
If you add data to send to the cRIO, then you'll need to coordinate the Network Tables.
Unread 29-01-2013, 21:45
AKA: William Burk
Ok, well if i didnt need a customized dashboard, if i toggled camera feeds, could it still just use one camera tab?
Unread 29-01-2013, 22:00
You'd need a separate tab or screen space for a separate camera, because one cameras display would overlay the other if you tried to stack them in the same spot. The tab is sort of how you'd toggle.
The feeds are coming from different IP video servers, so they will be two separate feeds.
Unread 29-01-2013, 22:14
AKA: William Burk
What I mean by toggle is turn one feed off while the other one is on. If we did that, would we get a lot of delay switching between the two?
Unread 29-01-2013, 22:24
Not a lot of delay, no.
I seem to remember some issue with restarting the camera after being halted for an extended length of time. But that may have been solved.
Unread 29-01-2013, 22:26
If the cameras are both plugged directly into the DLink on the robot, the cRIO doesn't even have to be powered for the dashboard to request images from one or the other, or both cameras. To change which is displayed or add a display, you would customize the dashboard.
You could put the cRIO to work doing this read and retransmit task, but that is the sort of thing it had to do in 2009, and it is much preferred to do it with the DLink.
Greg McKaskle
AKA: William Burk
Now, do you have any idea how to program that toggle switch in there, or can direct me to someone who has done it?
Unread 29-01-2013, 22:36
If you are asking me, I'm not sure I understand the question. I have added three cameras to a dashboard before and I've described how to do it on these forums. You need to duplicate the video loop or if you are running at the same framerate, you could open both and get the images in the same loop.
Greg McKaskle
Unread 29-01-2013, 23:16
AKA: William Burk
I found a guide and from a quick look at it, it looks like what we need. Thanks for the help.
