Go to Post Yes, I'll admit it...I had a crush on Ken Leung when we all went out together for the college night in 2002. - Elgin Clock [more]
Unread 21-01-2003, 15:09
Andrew Dahl's Avatar
Andrew Dahl Andrew Dahl is offline
#0497 (Orange Crush)
Andrew Dahl is an unknown quantity at this point
drivetrain mouts and gears
does anybody know if we are allowed to use more than two of the black plastic drivetrain mounts on the robot?
Thanks for any help.
2002 VCU Regional winner of the GM Industrial Design award
whooot!
Unread 21-01-2003, 16:00
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
You can use as many as you want! ( I would assume you mean the gearboxes and not the motor mounts....they're for the drill motors and you can only have two drill motors)
~Adam
Unread 21-01-2003, 17:33
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
You can use as many as came in the kit, plus however many you want to build.
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 22-01-2003, 13:21
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
I am agreeing with adam on this one, you can use as many of them as you want, the order form is in the manual I do belive.
this year, if it is not explicitly forbidden, you can use whatever you want in the quantities you want as long as no rule forbids it.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
