Go to Post Sometimes, it's all about the people. - nixiebunny [more]
Unread 29-01-2013, 23:47
CrazyRussian96's Avatar
CrazyRussian96 CrazyRussian96 is offline
pneumatic/electrical derp
AKA: Dennis Chertkovsky
FRC #3492 (Putnam Area Robotics Team P.A.R.T.ƨ)
Team Role: Electrical
CrazyRussian96 is an unknown quantity at this point
Reasoning for R44
The wireless bridge power feed must be supplied by the 12VDC-to-5VDC converter (P/N: CLL25-24S05) connected to the marked 12VDC supply terminals at the end of the PD Board (i.e. the terminals located between the indicator LEDs, and not the main WAGO connectors along the sides of the PD Board) shown in Figure 4?8. No other electrical load may be connected to these terminals.
What exactly is the reasoning for the first part of rule R44 in the Game Manual? My intuition tells me that it is to prevent the D-Link from experiencing power loss due to an accidentally tripped breaker, which would cause the robot to become out of control. No amount of searching on the internet (and Chief Delphi) has yet found me a concrete answer beyond "Do this because the rule says so". Can anyone please confirm/disprove/elaborate on my idea?
I haven't thought of a good quote yet, so have a nice day!
Unread 29-01-2013, 23:52
Joining the 900 Meme Team
FRC #0079
Re: Reasoning for R44
Conjecture - The 12v output is regulated as opposed to the regular outputs which are simply output from the battery. You could check this by looking at the design of the PD board.
Unread 30-01-2013, 00:13
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
The special 12VDC supply on the Power Distribution Board is a "boost" supply, which will supply 12V even when the battery voltage falls way below 12V. For more information, see the PDB spec sheet at http://www.usfirst.org/sites/default...on%20Board.pdf
From looking at the specs, it appears that 11V will be guaranteed from the "boost" supply even if the PDB input voltage (the battery) falls all the way down to 4.5V.
The boost supply is important for the wireless bridge, because it prevents the wireless bridge from rebooting (which takes about a minute) every time the robot suddenly draws a huge rush of current (say due to a pushing match) which could temporarily drop the voltage to well below 12V.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 30-01-2013, 08:19
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Exactly what Ken said. Anywhere else you get a momentary voltage drop. Bridge reboots. Comms drop. Robot stops. It was one of the issues documented in the Einstein report last year.
Unread 30-01-2013, 16:04
Thanks for all of the responses!
Unread 02-02-2013, 04:30
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Although I understand that reasoning, does not the DC-DC converter do the same thing? When the input voltage drops, at what point does it's 5v output shut down at? Since it converts to 5v, even if it doesn't operate as a boost-buck module, it ought to be good to 6v in.
In addition, the D-link routers internal regulators work just fine at 12v and do their own internal conversion to 5v or whatever they use internally. We run them routinely on an old robot that was wired for the old Linksys bridge. (Discovered by accident, when a student didn't realize they weren't direct plug-in replacement)
It seems like all these voltage conversions are inefficient and redundant.
If your battery is dropping below 6v then you're probably only seconds away from it dropping below 4.5v anyway. Continuing to run like that only damages batteries.
Note that this is just a theoretical discussion. If your robot is not wired to the current rule, I'll still call you out on it in inspection!
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 02-02-2013, 04:40
The power supplies are staged such that motor power is intentionally cut a volt or so before the brains and radios cut. This helps prevent death during pushing matches, but doesn't replace having fully charged batteries.
