Go to Post I find it quite amazing that this thread has been continuously active for more than two years. - Stephanie [more]
Unread 30-01-2013, 11:02
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
Smart Dashboard getting cluttered
We have several different team members on our team this year trying out the Smart Dashboard. It's our first year using this - so it's completely new to us. One of the things I'm noticing is that, even when I just have a very simple program written with one "number" field sent to the Smart Dashboard, I am getting a lot of things thrown into it. I've tried physically "edit" the Dashboard and removed them, then saving the blank dashboard. However, when I restart the dashboard and start up my simple program. All of the old stuff reappears.
Is this happening to other folks as well, and if so, is there a way to completely wipe it? Is it something being stored from the cRIO side? or on my laptop side?
Unread 30-01-2013, 13:25
mitchellweb1 mitchellweb1 is offline
AKA: Mitchell W
FRC #0190
mitchellweb1 is an unknown quantity at this point
Re: Smart Dashboard getting cluttered
What are the other values that are showing up? If you want to remove values that auto-populate then put the smartdashboard in edit mode (View>Editable) and then right click on the widget and click remove. To add the widget back select the appropriate widget under the View>Reveal menu. Static widgets like the camera extension must be readded through the add menu each time.
Unread 30-01-2013, 13:53
Here's information about the Smart Dashboard and "stale" data: http://wpilib.screenstepslive.com/s/...smartdashboard
Unread 30-01-2013, 17:42
Thanks Joe, That's kinda what I was looking for. Guess, I'd have to have everyone restart their laptops and then also recycle the cRIO as well.
Unread 30-01-2013, 17:50
Not reboot the laptop, just close the SmartDashboard (if open) before running the new cRIO code, then re-open it after the code has been loaded.
Unread 19-02-2013, 21:02
DaboRoss's Avatar
DaboRoss DaboRoss is offline
User.
FRC #4030 (NullPointerException)
DaboRoss is an unknown quantity at this point
My program auto-changes debug levels by a switch on the smartdashboard, so I am wondering if there is ANY way to remove these values from the robot code. Even if it would require something like an edited smartdashboard, and custom network tables.
~Dabo Ross
