Re: Hall Effect Sensors
Hey! Finally somebody who knows where the "macro" button is on their camera
Oh no! I forgot to put the Gaussian blur effect on!
I feel your pain with the atrocious camera phone shots trying to clarify something. |
We (3132) are using hall effect sensors with a buffering circuit this year. We developed them in the off-season for our 2012 shooter wheels.
We use Hall Effect sensors from RS (http://australia.rs-online.com/web/p...-ics/7384743/). We are mounting the board flat underneath our shooter wheel, and 'hanging' the magnets down off the wheel. The magnets are epoxied into a piece of aluminium hex stock that was turned to a taper and had a hole drilled in it for the magnet. A thread was then tapped into the other end of the piece, to mount it on the end of the bolt holding the wheel on. When mounting them, make sure that the sensor itself can't move, so that it can't be sheared off by whatever it's measuring or drift away from the magnet. I'm attaching a picture of the board, and a picture of our magnet mounts (before the pcb is attached), as well as the schematic for the buffering circuit. Let me know if you have any questions. |
A useful gear tooth sensor that wires directly into a digital input is the Allegro Microsystems ATS667LSG. We like to use them when we need speed information but not direction information and we don't need the highest resolution. We also like that they're $6.
In the photo below an ATS667LSG is mounted to a carrier board and installed in the side of a Cim-u-lator gearbox, with its face about 0.03" from the output gear. It gives us a nice, clean 27 pulses per output shaft revolution. The sensor on top of the right motor is just posing for the photo. ![]() |
That's a good question. I told the student writing the code what to expect for a signal, and he said "Yeah, I got this".
#7
Could you ask him to join the discussion here? |
#8
1. Where did you purchase them? 2. Did you wire them with the bypass and lowpass capacitors? 3. Do you have any data on how it performs on chain sprocket teeth? |
#9
.....steel? aluminum?
#10
Steel. Gear Tooth Sensors have an embedded rare-earth magnet along with a hall effect sensor. They detect a change in the magnetic field that you're not going to see with a non-ferrous target.
EDIT: Also, Digikey has 22,690 in stock. Better order quick before they run out. Last edited by Kevin Sevcik : 01-02-2013 at 17:03. |
#11
Thanks for the source info though. We'll get our order in ASAP! |
#12
It was a serious question, Dave, because the sprocket is aluminum and I thought they only worked on ferrous teeth.
#13
2. The capacitor hiding in the epoxy is a 0.1uF 50V ceramic across power and ground. 3. We haven't tried reading sprocket teeth, but I would expect them to work well with steel sprockets and a small air gap. |
#14
Electrotoken, am I right in thinking that the magnets in the hall effect sensor in the ATS667LSG detects the disturbances in the fields from the magnets mounted in the sensor package as the steel gears in the gearbox rotates through the field? Did you just connect it into one of the digital inputs on the Digital Sidecar? The datasheet does not seem to show any sort of calibration. Did you just stick it on, connect the wires and run? |
#15
It really is as simple as wiring into the digital sidecar and counting pulses. We used two of these last year and will be using three this year. |
