Go to Post Our coolant system consists of a freshman with a squirt bottle. - Holtzman [more]
Unread 30-01-2013, 11:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
US Digital Encoders - How many CPR?
Forgive me, I'm not a programmer and my students won't be here until this afternoon. This is a rather simple question but I couldn't find the answer. Can we use any number of count US Digital Encoders with Java? The students asked me to purchase 250 count, but I'm wondering if some lesser count would be better for high speed things. Is Java set up to use any number of count encoders? We may need to read three simultaneously if that makes any difference.
Unread 30-01-2013, 12:11
Re: US Digital Encoders - How many CPR?
The FPGA can decode approximately 153k edges per second and can handle 8 single channel counters and 4 two channel encoders simultaneously (each at 153k). If you're using a quaderature encoder (with four edges per count, the max is approximately 38k). This is the same across all languages. Neither the FPGA or the code care how many counts the encoder is, as long as it doesn't exceed 153k/38k limit. If you're running a shooter that only runs in one direction, you only need to use a single channel of the encoder with a counter object.
There is good discussion in the following thread about how the FPGA's clock rate affects the noise in measuring periods at high speed. http://www.chiefdelphi.com/forums/sh...d.php?t=112193. I recommend playing with the spreadsheet that Ether posted in that thread. The averaging feature used in that spreadsheet isn't user-accessible in Java, without recompiling WPILib. It wouldn't be hard to add, however. Without using averaging, it is better to use a lower count encoder.
Unread 30-01-2013, 16:57
Thanks for the help Joe. You posted just in time before I had to put the order in.
Unread 30-01-2013, 17:38
The quadrature encoder uses two separate DIO channels. On each channel, there are only 2 edges per cycle (one rising and one falling).
So shouldn't the max be 153K/2 instead of 38K? Or do the two FPGA channels get tied together somehow when you configure them for quadrature decoding, so that each channel is no longer capable of 153K?
Unread 30-01-2013, 18:14
I got that from an old post on the NI forums from Joe Hershberger. https://decibel.ni.com/content/message/12541#12541 It probably has to do with quadrature detection for direction. It seems like it would need one clock in each of the 4 states.
Unread 30-01-2013, 18:17
Thanks. I'll check with Joe and share what I find out.
Unread 01-02-2013, 13:53
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
My understanding is that the 4 quadrature decoders just use a single counter, counting rising and falling edges on two discrete lines which is why it is 38K max (and keeps track of A and B phase for direction). I do not believe it use two separate counters for each DIO channel.
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 01-02-2013, 14:29
No. A quadrature encoder uses 2 DIO channels. Each channel gets polled synchronously by the FPGA at 153KHz. Each channel counts its 720 edges at 153Khz.
But the encoder will not work if the elapsed time between rising edge on channel A and rising edge on channel B (or vice versa) exceeds 1/153KHz seconds, because the FPGA won't be able to tell which came first. That's where the 38K limit comes from.
