Go to Post Yes, I think we can all agree that bad people suck. - Joe Johnson [more]
Unread 30-01-2013, 11:07
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
LimitSwitch as Command Button
Is there a way to set a command to fire on the push of a limit switch in a similar way to the way joystick buttons are linked to commands?
Unread 30-01-2013, 12:02
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: LimitSwitch as Command Button
there is a subclass of Button called DigitalIOButton that should do what you want.
Unread 30-01-2013, 12:16
Flywheel Police
Awesome, I knew it was somewhere but I couldn't find it. Thank you.
That is designed for a driver station digital i/o, not on the robot. To do it on the robot, it would not be hard to create a class to extend Button that reads from a digital i/o on the robot. Alternately, you could create an InternalButton object and periodically call the setPressed method with the state of the limit switch.
Unread 30-01-2013, 12:24
Flywheel Police
My only worry is getting multiple triggers with one press from noise on the channel. We're trying to implement a frisbee counter that count frisbees coming in and leaving the robot. We tried using the Counter class, but we kept getting random increases in the count from the limit switches. I'm assuming there was noise as the switch was pressed which made it think that there were multiple presses.
Unread 30-01-2013, 12:46
AKA: Josh P.
Whoops, my bad. Yeah you should be able to extend Button then and use your own like Joe said. If you only want one activation in a certain amount of time you could make a Timer object internal to your class to make sure only one activation happens per amount of time.
Unread 30-01-2013, 12:48
The counter class acts as an interrupt and counts every single edge of the switch bounce, which isn't what you want.
The simplest method for dealing with switch bounce is to poll the switch slower then the duration of the switch bounce. This works as long as the process actuating the switch is "slow", which my guess is that a frisbee counter is. For example, if the switch bounces for 10ms, polling it every 20ms will give you at worst one reading during switch bounce. If you happen to sample low during the bounce, you're reading of the switch will be delayed 20ms (the next sample will be high). If you happen to sample high during the switch bounce, you will react immediately (and the next sample will be high). If you extend button to read the switch, it would automatically get called at 20ms.
The following paper has lots of examples of switch bounce, as well as examples of both hardware and software debouncing, if you determine you do need to debounce. http://www.eng.utah.edu/~cs5780/debouncing.pdf
If you extend Button, you could implement your debouncing algorithm in get method.
Unread 30-01-2013, 12:51
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
It is quite easy actually. You just extend Button and implement your own get() method to return the limit switch input. Add your own debouncing and you are good.
Here is my code (I haven't implemented any debouncing)
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package edu.wpi.first.frc3946.MyTest;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.buttons.Button;
 * @author Gustave Michel
public class IOButton extends Button {
    DigitalInput button;
    public IOButton(int port) {
        button = new DigitalInput(port);
    public boolean get() {
        return button.get();
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 30-01-2013, 12:52
Flywheel Police
You can set the Counter class up to only read the leading or trailing edges, so that isn't a worry. We'll probably end up extending the Button class and doing it that way. We might end up with IR pairs as the counters so the Button class would give us the most flexibility. Thanks for the info.
Unread 01-02-2013, 08:11
Flywheel Police
Thanks guys, overriding the Button class worked great, and there was no bouncing at all. The thread must process slower than the bounce happens so we didn't have to worry about it.
