Go to Post The neat thing about regionals, is that they ARE big robot parties! - MrForbes [more]
Unread 30-01-2013, 13:49
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Air Tanks?
Air tanks are out of stock on AM. Are their any rules regarding other tanks?
I see in the manual:
The only pneumatic system items permitted on 2013 FRC ROBOTS include the items listed below.
Items available in the 2013 KOP,
Pneumatic pressure vent plug valves functionally equivalent to those provided in the KOP,
Parker valves PV609-2 or MV709-2 are recommended.
Solenoid valves with a maximum 1/8 in. NPT port diameter, and a maximum Cv of 0.32,
Solenoid valves that are rated for a maximum working pressure that is less than 125 psi rating mandated above are permitted, however if employed, an additional pressure relief valve must be added to the low pressure side of the main regulator. The additional relief valve must be set to a lower pressure than the maximum pressure rating for the solenoid valve,
Additional pneumatic tubing, with a maximum 0.160 in. inside diameter, functionally equivalent to that provided in the KOP,
Pressure transducers, pressure gauges, and connecting fittings,
Pressure regulators with a maximum bypass pressure of no more than 60 psi,
Pneumatic cylinders,
Pneumatic storage tanks, and
Compressors compliant with R80.
Could we use something like this: http://www.etrailer.com/Accessories-...one/F9125.html ?
Unread 30-01-2013, 14:14
Re: Air Tanks?
Matthew,
It must meet the minimum requirements for working pressure ratings.
R76
All pneumatic components must be COTS pneumatic devices rated by their manufacturers for working pressure of at least 125psi (with the exception of R78-D).
Unread 30-01-2013, 14:17
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Air Tanks?
looks like it's rated for 150 PSI. But, it's 7 pounds...
Unread 30-01-2013, 14:32
G Fawkes G Fawkes is offline
FRC #1290
G Fawkes is an unknown quantity at this point
Re: Air Tanks?
Andy Mark has stainless steel tanks that we have used in the past (on sale too).
http://www.andymark.com/product-p/am-0845.htm
I suspect the plastic tanks are "out of stock" while they sort out the issue with the tank that failed recently.
Si Se Puede
Unread 30-01-2013, 14:34
FRC #6054 (Dukes)
Re: Air Tanks?
It is heavier than I would like. Can anyone offer some good alternatives?
Unread 30-01-2013, 14:43
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Air Tanks?
An alternative supplier for the plastic air tanks is Pneuaire.
Unread 30-01-2013, 14:58
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
Re: Air Tanks?
I'd love a bit bigger plastic air tank if someone runs into it. Something more like 1/2 to 1 gallon would be ideal.
-Mike
Unread 30-01-2013, 15:11
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Air Tanks?
Andy took the Clippard tanks off the site due to the incident that occurred over the weekend with a team. Supposedly FIRST is going to be sending something out in an email blast about it to all teams.
The Pneuaire tanks that Justin mentions are your best option. FIRST tested and approved. We have used them the past 2 seasons and plan to use them this season.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 30-01-2013, 18:56
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Air Tanks?
Agreed, we replaced our metal Clippard tanks with the 44 cubic inch Pneuaire tanks for IRI last year, and had no issues with them.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
