Go to Post They truncated our conference title. We are not showing the movie "Finding NEMO" - RoboMom [more]
Unread 30-01-2013, 15:50
DBortnick's Avatar
DBortnick DBortnick is offline
AKA: Daniel
FRC #1850 (Mechanicats)
DBortnick is on a distinguished road
Question Torn Banebots Motor Terminals
Oy, Team 1850 learned a good lesson today:
Don't attach wiring to your motors while you are still moving them around and mounting them. We had the terminals on our Banebots motors get torn off and mangled (see the attached picture).
Have any other teams had this happen in the past? Would soldering leads back on work? Any other ideas or does the motor just need to be replaced?
(Edit: The terminal on the left is the torn one and the one on the right was ripped clean off
Even more specifically would this break R33 sub point b?)
Name:	broken motor terminals.jpg
Coach for Team 1850
ACE Technical Mechanicats - Chicago, IL
http://www.facebook.com/Team1850
Unread 30-01-2013, 15:57
Re: Torn Banebots Motor Terminals
You're not alone.
Every team seems to need to learn this lesson the hard way:
When you attach the wires to the motor terminals, stress relieve them to the side of the motor case with epoxy or something.
BTW, I'm doing a little informal research: Does your camera have a macro button?
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
We cut ours short and solder on wires when we don't have room for a larger connection. Just be carful to avoid the motor case and don't melt the plastic insulation and it might work just fine. That ripped one may be tough though...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 30-01-2013, 16:01
DBortnick's Avatar
AKA: Daniel
You're not alone.
I'm using the camera on my iphone 5. What are you trying to see?
Coach for Team 1850
Unread 30-01-2013, 16:08
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
The macro button on a camera makes taking close pictures like that clearer. Without it (either not using it, or using a cell phone camera that doesn't have one) and the close up detail becomes blurry.
2016: Lake Superior WFFA
Unread 30-01-2013, 16:10
Daniel,
We use crimp terminals that are right angle types. We of course solder everything, very carefully. Then the wires are formed down the side of the motor and ty-wrapped in place terminating in Anderson Power Poles. The rest of the wiring then runs along the frame and is ty-wrapped there as well.
Unread 30-01-2013, 16:13
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Daniel,
This is very similar to what we do.
OP: note that TWO zip-ties spaced some distance apart are required to anchor the wires to the motor can. If only one zip-tie is used it becomes a fulcrum and the motor tabs still get stressed.
Unread 30-01-2013, 17:07
JDL JDL is offline
Systems Integrator
FRC #0498
JDL is just really niceJDL is just really niceJDL is just really niceJDL is just really nice
We had a problem with that, we too started to use flag crimps and tacked them inplace with solder and put some glue around each connection for a little extra protection.
Unread 30-01-2013, 17:43
DonRotolo's Avatar
Back to humble
FRC #0832
What JamesCH75 wrote^^
We have had limited success in getting some solder onto ripped off terminals, but we won't use these for competition, only practice machines.
Terminal repairs that don't open the case are, in my opinion, perfectly legal.
Unread 30-01-2013, 17:45
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Another good idea is to to take a small piece of PVC pipe and cut a section out of it so it looks like a C. You can than stretch that over the motor and have some of it stick out the back over the wires. This protect the wires from impact. Be careful not to cover the heating vents.
Unread 30-01-2013, 17:55
DBortnick's Avatar
AKA: Daniel
We are in the middle of soldering the terminals and double checking to make sure that it is isolated from the rest of the motor. We will then mount the wires in two different places to make sure that it is not jerked around.
Thanks all for your suggestions!
Coach for Team 1850
Unread 30-01-2013, 17:56
DBortnick's Avatar
AKA: Daniel
When you did this, did you have any issues with the heat from the wires melting the glue?
Coach for Team 1850
Unread 30-01-2013, 18:05
JDL JDL is offline
Systems Integrator
FRC #0498
I used some 2 part epoxy.
