Go to Post edit: laptop. yeah as a programmer to not put this in I should be taken out the back and "decompiled". - Stuart [more]
Unread 30-01-2013, 18:21
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Extending a Hex Shaft?
Does anyone know of a simple (cheap) way to extend a hex shaft? We have a need to couple the end of a Versaplanetary to a longer hex shaft but haven't been able to find a cheap 1/2" hex shaft collar.
Any suggestions for teams without a lathe or a mill?
Unread 30-01-2013, 18:28
Re: Extending a Hex Shaft?
Know a local team with a hex broach?
Unread 30-01-2013, 18:36
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
It might not be pretty, but you could probably use a modified AM Hex Hub (http://www.andymark.com/product-p/am-0096.htm).
--Madison--
...down at the Ozdust!
Unread 30-01-2013, 18:41
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
http://www.mcmaster.com/#male-female...ndoffs/=l9l4gb
Maybe one of these?
The issue would be you would need to tap the end of the output shaft, and you would need that to be in line with the axis of the shaft.
Good enough is the enemy of anything great!
team 1671
Unread 30-01-2013, 18:45
Engineering Coach
Not that I know of, but probably. With all the hex stuff now we should probably get one soon, but we would have to buy a bigger arbor press for that as well.
That was my first thought and was hoping there was another way to do it.
Unread 30-01-2013, 18:47
Aren_Hill's Avatar
Build Nifty Things
What diameter clearance do you have? you could get quite creative with bolting some hex hubs together with standoffs.
possibly take a tube with a close enough inner diameter and shoot two pins through it to retain the shafts?
The VersaPlanetary 1/2" hex output also has a 1/4-20 hole in the end, you could possibly tap the end of the other piece of hex shaft, take a short piece of threaded rod, twist the two together then take a 1/2" Hex shaft collar on the outside to overlap the two which would transfer the torque.
Just spitballin here
A guy who likes robots.
Unread 30-01-2013, 18:52
FRC #5817 (Uni-Rex)
I did not realize that versa planetary gearboxes came with a hole on the end.
Just use the male end half inch hex standoffs from mcmaster I posted the link earlier.
team 1671
Unread 31-01-2013, 20:29
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
You can always throw away the shaft that came with the gearbox and make you own longer shaft out of some hex stock. We have done this a few times with planetary gearboxes. It will probably involve turning one end round, adding a snap ring groove, and milling some flats. This is very doable with a manual mill and lathe.
Unread 31-01-2013, 21:55
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 31-01-2013, 21:58
pfreivald's Avatar
AKA: Patrick Freivald
Is there a team nearby with a lathe or mill that would be willing to make you a coupler (or a longer output shaft)?
For future years, I highly, highly suggest getting a small benchtop lathe and mill -- all told they'll run you close to $2K, and problems like these just evaporate.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 31-01-2013, 22:14
Aren_Hill's Avatar
Build Nifty Things
VersaPlanetary gearboxes have a spline on the output shaft with much higher torque carrying capability than the flats of other gearbox shafts.
Making your own spline would require a lot of effort
Unread 31-01-2013, 22:19
Engineering Coach
It's not a money issue we have extremely limited space. I know your mobile cart solution and if we even had a closet I would do that but we don't. We also don't have anyone who knows how to use a lathe or a mill (outside of my extremely limited experience).
Unread 31-01-2013, 22:35
pfreivald's Avatar
Wow. The table's about the area of two-and-a-half FIRST totes put end-to-end, and holds most of our hardware in addition to the machines (which I'm certain *someone* would help you learn how to use!) I can't imagine even trying to build a robot without enough space to store something like that.
Team 1551
I write books, too!
Unread 31-01-2013, 22:39
Engineering Coach
Maybe if it's that small, but we share space with other things in the school. So we have space but we have to clean up most nights.
Unread 31-01-2013, 22:41
craigboez's Avatar
Mechanical Engineer
I hadn't bothered to look at the inner workings of the VersaPlanetary until now. That is quite a spline. Since we a) never use planetaries for high torque applications and b) like to customize the output shaft I don't see us investing in these any time soon.
So as a follow up to my original suggestion, first buy a Banebots P60 and then DIY the output shaft.
