Go to Post We also indirectly benefit from those rookie teams having well-built and working drivebases. It helps raise the level of performance across the board, making for a better competitive environment. - Alan Anderson [more]
Unread 30-01-2013, 19:36
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
Unhappy cRIO problem
hii guys we are rookie team and i dont know wats wrong with our cRIO Imaging tool. when i scan it work everything fine but its taking so long so long to reboot idk that's good or not but i need help with that please.....thank you
Unread 30-01-2013, 19:55
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
Re: cRIO problem
What is taking a long time to reboot? The cRio or the Imaging Tool?
Two issues I have had in the past.
- Make sure the cRio is plugged in.
- Make sure the modules are in the right slot.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 30-01-2013, 20:05
AKA: Akash
FRC #4684
Re: cRIO problem
the imaging tool is good but when is rebooting its talking way too long idk..
Unread 30-01-2013, 20:33
saikiranra's Avatar
UCI
Re: cRIO problem
I'm going to be assuming that the imaging tool is taking too long to reboot.
They update the tool, every so often.
Check here: http://www.usfirst.org/roboticsprogr...ical-Resources
Unread 30-01-2013, 20:36
AKA: Akash
FRC #4684
Re: cRIO problem
I did update though idk its same thing..
Unread 30-01-2013, 20:50
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Re: cRIO problem
Boot the cRIO into safe mode by holding the reset button for 5 seconds until the status light stays solid yellow, then try again.
Unread 30-01-2013, 20:52
Re: cRIO problem
Have you tried all the troubleshooting steps listed at the bottom of this document?
AKA: Akash
FRC #4684
Re: cRIO problem
OK
Unread 30-01-2013, 20:59
AKA: Akash
FRC #4684
Re: cRIO problem
Any other ideas??
Unread 30-01-2013, 21:02
Re: cRIO problem
Originally Posted by akash992391 View Post
Any other ideas??
You've tried disabling all other network adapters, tried with and without a switch in-between, and checked that the netmask is 255.255.255.0 as detailed by the page I linked to?
Unread 30-01-2013, 21:05
AKA: Akash
FRC #4684
Re: cRIO problem
ok i will try that thanx...
Unread 31-01-2013, 17:54
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: cRIO problem
I'm fairly certain formatting a cRIO while in SAFE mode corrupts the cRIO, so I would suggest not doing this.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 31-01-2013, 19:57
Re: cRIO problem
It does not corrupt the cRIO. It does require a two step imaging (image the cRIO in safe mode, then reimage the cRIO not in safe mode).
Unread 31-01-2013, 20:01
AKA: JD Russo
Re: cRIO problem
This is incorrect. As was said, it simply does a two step imaging, and the 2013 Imaging Tool will handle that for you. From the user's end, you only need image it as you would were it not in safe mode, and click the dialog to confirm formatting it. In no way does it corrupt the cRIO.
Unread 31-01-2013, 20:05
AKA: Spencer Lanman
Re: cRIO problem
My apologies I must of read some incorrect information somewhere.
Shooter Operator
Catapult Operator
Chainsaw Operator
