Go to Post Actually, I think the standard Klingon warning label ought to be sufficient: 'yIQIpQo' (don't be stupid) - Alan Anderson [more]
Unread 28-01-2013, 22:35
l0stboy l0stboy is offline
FRC #4064 (InZombiacs)
l0stboy is an unknown quantity at this point
Can't figure out Roborealm. Need distance variable
Hello. I'm completely new to Roborealm, but I know my way around the WPI Java stuff. I'm having a hard time understanding the Roborealm tutorial. I have the given sequence of modules given here :http://www.roborealm.com/FRC2013/slide060.php
However, when I try to use Network Tables, I can't seem to find the option to send the distance variables or have anything with "SmartDashboard" show up as it has it here: http://www.roborealm.com/help/Network_Tables.php
My end goal is to have Roborealm process the image in order to send over the distance variable to the cRIO for shooting processing.
Also, what would I use the SmartDashboard to do with the camera. I'm also having trouble getting the camera image showing up on the Driver Station.
Help would be very much appreciated.
Pedro
Ocala InZombiacs
Unread 28-01-2013, 23:06
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: Can't figure out Roborealm. Need distance variable
Use a "Set Variable" module to rename the variable
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 30-01-2013, 21:00
So would the pane on the left be what we want to call the variable in Java and then the right is what the variable is in Roborealm?
Pedro
Ocala InZombiacs
Unread 01-02-2013, 15:40
RoboRealm RoboRealm is offline
FRC #0443
RoboRealm is a jewel in the roughRoboRealm is a jewel in the roughRoboRealm is a jewel in the roughRoboRealm is a jewel in the rough
Pedro,
The left is what exists in the network tables system, and the right is what exists in RoboRealm. So, yes, if you are using Java to access the network tables system then that would be the variable that you need to query i.e. /SmartDashboard/Distance. The reason for the /SmartDashboard/ prefix is so that it also shows up in the SmartDashboard app which uses that prefix as its namespace.
Note that we updated the robofile in
to include the network tables module with the Set_Variable module to rename them into the SDB namespace.
STeven.
Unread 03-02-2013, 23:11
Ah, I get it now. So would my code look like this to get the distance value out of RoboRealm and into the cRIO?
NetworkTable server = NetworkTable.getTable("SmartDashboard");
try
System.out.println(server.getNumber("Distance", 0.0));
catch (TableKeyNotDefinedException ex)
Pedro
Ocala InZombiacs
Unread 04-02-2013, 02:09
FRC #0443
Yup, that's right. That's why you need to rename or call the variable with the /SmartDashboard/ prefix in it. The call to getTable needs that.
STeven.
