Go to Post My friend Noah said he talked to someone that knew me from Chiefdelphi. That's just creepy. - Adam Y. [more]
Unread 30-01-2013, 21:17
r0306 r0306 is offline
AKA: Robert Lu
FRC #0253 (MRT)
r0306 is an unknown quantity at this point
Netbeans Stuck at Deploying Code
We're using the default robot drive code and deploying to the cRIO through NetBeans. The console shows that it has established connection to the cRIO. However, we've waited for 30 minutes and the code still hasn't finished deploying. Here is the log:
clean:
Deleting directory C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build
Created dir: C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build
Created dir: C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\classes
[crio-compile] ./src, C:/Users/MRT253/sunspotfrcsdk\lib\wpilibj.jar;C:/Users/MRT253/sunspotfrcsdk\lib\networktables-crio.jar, C:/Users/MRT253/sunspotfrcsdk\lib\squawk.jar -> ./build/classes
Compiling 1 source file to C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\classes
compile:
preverify:
Created dir: C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\preverify
Created dir: C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\preverify.raw.util
[crio-preverify] ./build/classes, , C:/Users/MRT253/sunspotfrcsdk\lib\wpilibj.jar;C:/Users/MRT253/sunspotfrcsdk\lib\networktables-crio.jar, C:/Users/MRT253/sunspotfrcsdk\lib\squawk.jar -> ./build/preverify
Expanding: C:\Users\MRT253\sunspotfrcsdk\lib\wpilibj.jar into C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\preverify
Expanding: C:\Users\MRT253\sunspotfrcsdk\lib\networktables-crio.jar into C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\preverify
jar:
[crio-jar] ./build/preverify, ./resources -> ./build/app.jar
Building jar: C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\app.jar
suite:
Created dir: C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\suite
[crio-suite] ./build/app.jar -> ./build/suite/image
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 377 classes and generated 4 files.
Expanding: C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\app.jar into C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\suite
Moving 1 file to C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\build\suite
Deleting: C:\Users\MRT253\Desktop\FRC2013\Robot Code\2013 Robot Code\image.suite.api
deploy:
[crio-configure] Configuration files not included in this version of the sdk
[crio-configure] Checking that crio is configured for Java
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) 64-Bit Server VM 23.0-b21
Target IP: 10.2.53.2
Network interfaces on host:
    Realtek RTL8188CE Wireless LAN 802.11n PCI-E NIC:  address: 10.5.5.97 netmask: 255.255.255.254
    Atheros AR8152/8158 PCI-E Fast Ethernet Controller (NDIS 6.20):  address: 10.2.53.5 netmask: 255.255.255.0 <--- on robot's subnet
Connecting FTP @10.2.53.2
[crio-deploy] ./build/suite/image.suite -> 10.2.53.2
Sending local file image.suite
run:
[cRIO] [OTA Server] ********* REBOOTING cRIO *********
[cRIO]
   Waiting for cRIO to reboot (1s)
   Waiting for cRIO to reboot (2s)
   Waiting for cRIO to reboot (3s)
   Waiting for cRIO to reboot (4s)
   Waiting for cRIO to reboot (5s)
   Waiting for cRIO to reboot (6s)
   Waiting for cRIO to reboot (7s)
   Waiting for cRIO to reboot (8s)
   Waiting for cRIO to reboot (9s)
   Waiting for cRIO to reboot (10s)
[cRIO]
[cRIO] -> * Loading debug.o: debug
[cRIO] Debugging is up, target server mounted at /tsfs
[cRIO]
[cRIO]
[cRIO]                 VxWorks
[cRIO]
[cRIO] Copyright 1984-2006  Wind River Systems, Inc.
[cRIO]
[cRIO]              CPU: MPC5200 -- Wind River Lite5200 BSP.
[cRIO]     Runtime Name: VxWorks
[cRIO]  Runtime Version: 6.3
[cRIO]      BSP version: 2.0/10
[cRIO]          Created: Jun 14 2012, 08:46:35
[cRIO] ED&R Policy Mode: Deployed
[cRIO]    WDB Comm Type: WDB_COMM_END
[cRIO]              WDB: Ready.
[cRIO]
[cRIO] * Loading nisysrpc.out: nisysrpc
[cRIO] * Loading NiRioRpc.out: NiRioRpc
[cRIO] * Loading nivissvc.out: nivissvc
[cRIO] * Loading nivision.out: nivision
[cRIO] NI-RIO Server 12.0.0b10 started successfully.
[cRIO] task 0xdb0db0 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
[cRIO] * Loading visa32.out: visa32
[cRIO] * Loading niserial.out: niserial
[cRIO] * Loading NiFpgaLv.out: NiFpgaLv
[cRIO] * Loading FRC_FPGA.out: FRC_FPGA
[cRIO] * Loading FRC_NetworkCommunication.out: FRC_NetworkCommunication
[cRIO] FRC_NetworkCommunication version: p4-1.4.0a10
[cRIO] FPGA Hardware GUID: 0xA14C11BDE4BB64AEF6A86FC52A294CD9
[cRIO] FPGA Software GUID: 0xA14C11BDE4BB64AEF6A86FC52A294CD9
[cRIO] FPGA Hardware Version: 2012
[cRIO] FPGA Software Version: 2012
[cRIO] FPGA Hardware Revision: 1.6.4
[cRIO] FPGA Software Revision: 1.6.4
[cRIO] * Loading FRC_JavaVM.out: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2012 FRC, Jan  5 2012, 17:20:48
[cRIO]
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 12.0rc7
[cRIO] task 0xcb5db8 (sysapi-rpc) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO] [Squawk VM] Version: 2011 FRC, Nov  5 2011, 14:34:13
[cRIO] FPGA Hardware GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9
[cRIO] FPGA Software GUID: 0xa14c11bde4bb64aef6a86fc52a294cd9
[cRIO] Default robotInit() method running, consider providing your own
[cRIO] Default disabled() method running, consider providing your own
[cRIO] edu.wpi.first.wpilibj.networktables2.server.ServerConnectionAdapter@8 entered connection state: GOT_CONNECTION_FROM_CLIENT
[cRIO] edu.wpi.first.wpilibj.networktables2.server.ServerConnectionAdapter@8 entered connection state: CONNECTED_TO_CLIENT
It stays on the last line and doesn't display a build successful. The code isn't loaded on the cRIO either because the driver station says that none is running. Are we doing something wrong here?
Unread 30-01-2013, 21:38
Re: Netbeans Stuck at Deploying Code
The log you have posted indicates that the code has deployed and finished loading. The build never "completes", the console output continues to get displayed in the output tab.
After the output of Netbeans got to this point, the DS showed a green light next to Communications, but red next to Robot Code?
Are you following the tutorial here?
Unread 30-01-2013, 21:45
AKA: Robert Lu
FRC #0253 (MRT)
No, actually there are green lights next to both. However, nothing is actually happening when I try to move the robot. The console on the driver station shows:
FRC:  The Driver Station has lost communication with the robot.
WARNING <Code> 44008 occurred at FRC_NetworkCommunications <radioLostEvents>  0.000 <radioSeenEvents>
FRC:  Robot radio detection times.
Warning <Code> 44003 occurred at Driver Station
<time>1/30/2013 4:49:08 PM<unique#>13
FRC:  No robot code is currently running.
WARNING <Code> 44007 occurred at FRC_NetworkCommunications <secondsSinceReboot> 3.541
FRC:  Time since robot boot.
Warning <Code> 44002 occurred at Ping Results:  link-GOOD,  DS radio(.4)-bad,  robot radio(.1)-bad,  cRIO(.2)-GOOD,  FMS-bad Driver Station
<time>1/30/2013 4:48:47 PM<unique#>12
FRC:  Driver Station ping status has changed.
And it keeps repeating.
Unread 30-01-2013, 22:02
Those warning messages are informational messages from each time you reboot the cRIO, hit clear after the robot is connected and see if any new messages appear in the box.
Unread 30-01-2013, 22:12
AKA: Robert Lu
FRC #0253 (MRT)
Okay. The robot is working fine now. However, the warning message keep on spamming the window but it shouldn't be too much of a problem. Thanks for your help!
