Go to Post I urge teams to look beyond what you are given in the kit of parts and strive for more - sanddrag [more]
Unread 30-01-2013, 21:29
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
Re: Long deployment time.
We have a very interesting issue on top of slow deploy time. Whenever deploying code after a build has been run as startup, it gets stuck on "waiting for target" line, which is printed twice. The only way to get around this that we have found is to re-image the cRIO. any suggestions?
Unread 30-01-2013, 22:48
It's a bug. It's been explained on the Chief Delphi forums many times. Until the next LabVIEW update is released, the workaround is to close the Dashboard before trying to load new code into the cRIO.
