Go to Post A Guru teaching batteries at Exide: "Do not draw your power from up here, by your terminals. You must reach down deep into your plates and pull the energy from your entire being! You must prove yourself worthy to be FIRST power cells!" - KenWittlief [more]
Unread 30-01-2013, 22:58
gerberduffy gerberduffy is offline
FRC #0192
gerberduffy is an unknown quantity at this point
Lab View Runtime 2012 Live Camera Feed Issues
Hey guys! After updating our main driver station laptop (2GO PC E12) we've successfully installed the latest 2013 driver station, and all the necessary vi's appear to be present when FRC Driver Station starts up. However, one odd thing that has happened is that we seem to have lost the ability to get a live Axis cam feed. The software that we use runs with camera feed perfectly on LVR 2011 systems that we've updated to the 2013 driver station. We're a little at a loss as to why we seem to be having this problem. Have any other teams encountered problems with LVR 2012?
Unread 30-01-2013, 23:32
Re: Lab View Runtime 2012 Live Camera Feed Issues
Our camera works fine, after being configured using the provided utililty. We did have to turn on the live camera feed on the Dashboard by clicking the button under the image window, of course.
Unread 30-01-2013, 23:44
One change this year is that the DS need to connect to the cRIO for the camera to appear in the Dashboard. Could that possibly be the issue you're seeing?
