Go to Post At one of the registration days at the beginning of the year I actually made a sign saying: "I'm not smart isn't an excuse". - Mr. Pockets [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Unread 30-01-2013, 22:19
TheCrayButton's Avatar
TheCrayButton TheCrayButton is offline
FRC #3528
TheCrayButton has a spectacular aura aboutTheCrayButton has a spectacular aura about
LED Lights for the Robot (what do you use??!?!)
Hey, my team is going to put LED lights on our robot. What colors can you use on the robot while playing the game?? Also, where do you buy these LED lights???
Pleas help!
Unread 30-01-2013, 22:28
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: LED Lights for the Robot (what do you use??!?!)
Pleas help!
You can use any color you want to. Team colors are never a bad choice. We buy all of ours from SuperBrightLEDs
Just don't forget you need 12v LEDs. As for how you light them up, you can either connect straight to the PDB and have them turn on when you have the power switch on, or you can run them off the spike relays and control when you light them up
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 30-01-2013, 22:50
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
In past years our teams has used these...
http://www.amazon.com/SANOXY-Cold-Ca...dp/B000BUDHOA/
for lighting our robot (and driver's station). They can get a bit hard to fit into the robot though - particularly this year with the smaller frame - so we will likely be looking into different options.
Unread 30-01-2013, 23:49
FRC #3528
Thanks so much Team driven! REALLY appreciate it!
So just to clarify, we could use pink LEDs on our robot while playing on the field? I didn't know if there was a certain rule that said you couldn't.
Unread 31-01-2013, 00:09
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Just remember that your LEDs can't interfere or cause a hazard to any drivers' vision-- make sure they aren't too bright (I know this has never been an issue, but as a member of a competition team last year, I really hope it's addressed this year, because it can be really distracting and annoying as a driver).
Of course, I doubt it will be, but still, be courteous to your opponents and your teammates!
Note: This typically isn't an issue if the LEDs aren't directed at a particular place; it was mostly a problem last year because some of the goals were at eye level.
No rules against using LEDs as long as it isn't intended to interfere with drivers or robots
Unread 31-01-2013, 11:23
FRC #3528
Awesome! Thanks for your help guys. I really appreciate it!
We will make sure they are concealed well.
Unread 31-01-2013, 14:34
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
We used this strand of individually addressable LED's from Adafruit last year:
https://www.adafruit.com/products/306
They have arduino code, which is what we used last year, which we interfaced to the cRio (clunkily) through a pair of digital outputs. This year, I took the Arduino library and adapted it to use the SPI.h interface in Wpilib, so we should be able to have the lights respond to a lot more robot, driver, and game actions, and the wiring will be simpler.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 31-01-2013, 14:55
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Another great place to get 12V LED's is automotive stores, or the automotive department at places like Walmart. 12V LED strips are used by many to add interior accent lighting to their cars (like under the dash), and are perfectly compatible with the FRC electrical system. They most often have adhesive backs, can be applied either straight or curved, and can be plugged directly into the 12V WAGO connectors on the PDB.
2016: Lake Superior WFFA
Unread 31-01-2013, 15:32
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
http://www.amazon.com/Hitlights-Blue...words=blue+led
Just make sure that whatever lighting strip you use meets the custom circuits guidelines and is on an appropriate circuit. For instance, the lights we use need to be cut so we don't draw too much power from the solenoid breakout.
Unread 31-01-2013, 15:43
Night_Shade's Avatar
Night_Shade Night_Shade is offline
AKA: Mollye Coday
FRC #2389 (Oklahoma Storm)
Night_Shade is an unknown quantity at this point
Sounds like a pretty cool idea. (:
2389Oklahoma.. STORM
Unread 31-01-2013, 16:13
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
we have Ring light (fc13-060)
any Idia who we cane conect, we try using from PD 20 A conecting with Power Converter CPR-360 (am-0899) .
any paper about that
TEAM 1946-Tamra
Unread 31-01-2013, 16:33
Tom Line's Avatar
To connect the ring light, you can lead it straight back to the power distribution board and one of the 20 amp slots. If you'd like to turn it on and off, you'll need to hook it to a spike (or a talon/victor/jag if you want variable control).
Unread 31-01-2013, 16:45
The Ring Light is a 12V device - it needs to be hooked up to one of the 12V outputs from the PDB - the red and black WAGO connectors - or to a spike if you want on/off control.
Unless you have two Power Converters on your robot, it should only be used with the radio - no other electrical loads can be connected to it, per R44. Using a second one connected to the normal 12V outputs and an appropriately sized breaker would be allowed as a custom circuit, if you needed the 5V output for something.
Unread 31-01-2013, 16:46
AdamHeard's Avatar
Lead Mentor
Are you communicating to the Arduino over spi or directly to the lights over spi?
