Go to Post I think Dave has been spending time on icanhascheezburger. Either that or the fumes from his rendering machines have affected the grammar control portion of his brain. - rsisk [more]
Unread 30-01-2013, 21:13
Ivanoff's Avatar
Ivanoff Ivanoff is offline
AKA: Benson
FRC #0253 (MRT)
Ivanoff is an unknown quantity at this point
CIM Motor Burn Out Question
We at team 253 are working on our frisbee shooter. If we direct drive two 8" pneumatic tires with two CIM motors to launch frisbees, will the CIMs burn out? We're a relatively inexperienced team with no mentors so apologies for technical ignorance.
Unread 30-01-2013, 21:17
Keyreaper's Avatar
Keyreaper Keyreaper is offline
Keyreaper
AKA: Cyrus Duong
FRC #1710 (Revolution Ravonics)
Keyreaper is an unknown quantity at this point
Re: CIM Motor Burn Out Question
Well assuming the Frisbee don't jam up in your shooter and stall the motors. The short answer is no...
CTO/Head Programmer of Team 1710
Unread 30-01-2013, 21:22
Ivanoff's Avatar
AKA: Benson
FRC #0253 (MRT)
Another question: how would you go about directly attaching a CIM to an 8 inch pneumatic tire?
Unread 30-01-2013, 21:26
Keyreaper's Avatar
Keyreaper
AKA: Cyrus Duong
Depends on what type of pneumatic wheel you have. If they are these http://www.andymark.com/product-p/am-0970.htm you could attach couple of shaft bearings on it, throw a shaft on it, then attach a sprocket on the mounting holes on the wheel.
I'm a programmer so sorry if I'm not too much help...
Unread 30-01-2013, 23:46
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Search Mcmaster carr for shaft couplers.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 31-01-2013, 00:10
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
8mm Key Hub http://www.andymark.com/product-p/am-0320.htm
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 31-01-2013, 00:42
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Unless you stall a CIM, and continue to try to run it for a minute or two, they are pretty hardy and shouldn't burn out.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 31-01-2013, 08:59
Benson,
The wheels can cause some excessive vibration in the motor and that puts some intermittent loads on the motor. The output bearing is not meant for a lot of side loading so depending on how often you run this motor up to speed, it may produce some early wear in the bearings eventually leading to failure. As you prototype check the temperature of the motor every once in a while. If it doesn't pass the 5 second touch test, you are over stressing the motor. If it is warm to the touch but you can hold your hand on it for five seconds, it is likely running normal.
Unread 31-01-2013, 09:47
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Two issues cause most of the side loading on the shaft:
1. Wobble of the wheel, because they aren't perfectly balanced or centered.
2. External force on the wheel, such as when the disc compresses the tire.
This thread addresses balancing the wheel. If you have a fairly well-balanced wheel, the wobble will be acceptable at CIM speeds.
This thread contains advice from Andy Baker on how well the CIM motor can handle the side load due to disc-tire compression.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 31-01-2013, 12:41
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
The CIM does not depend on air cooling. They are pretty tough to burn out. I very much doubt if there will be a problem.
To connect to the CIM get some hubs from Andy Mark. They have some that are specifically intended to mount any of their wheels to a CIM, 8mm shaft diameter as I remember. If you want to support the shaft above the wheel also just attach another hub and attach a short shaft into a bearing.
Unread 31-01-2013, 13:07
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Direct driving from the CIM is fine for a shooter, in terms of gear ratio (You will likely see many teams with this setup). Depending on your wheel size, you may even prefer the mini-CIM (same diameter, 2/3's the length) because it has a slightly higher free speed RPM (6200 vs 5300).
However, as others have mentioned, be very aware of wheel balance and support for side loading - don't rely on the CIM motor bearings to support the side loading very long.
We actually siezed a CIM motor bearing during prototype testing after serious overheating that was left unchecked. We had plans all along to properly support both sides of the wheel with bearings, and use a coupler to the CIM, but we were getting by with a direct-drive hub for testing.
The pneumatic tire we had from Harbor Freight was seriously out of balance and had a severe wobble (not a problem for the hand truck use it was intended for). Despite our attempts to balance with washers, the vibration still shook our test stand and the loading on the motor limited our wheel speed to about 3400 RPM. After repeated testing, the screws holding the motor body together vibrated loose, and the rear motor bearing siezed. The motor was too hot to handle without gloves for at least 20 minutes afterwards.
With a properly balanced wheel this likely would not have happened, even with only the motor shaft supporting the wheel, but it is still a good design practice to try and integrate another bearing to take the side load if possible
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 11-02-2013, 14:30
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
We killed a CIM. It was in our drive train last year, and we went to put it in the DT this year, and it moves at 10% speed and you can stop it by hand.
Unread 12-02-2013, 07:39
Mathew,
check out the pictures here...
http://www.chiefdelphi.com/forums/sh...&highlight=CIM
This is likely what took out your motor. The heat generated internally eventually weakens the crimped wire to commutator connection and the wire fails by breaking off or pulling out.
