Go to Post I knew that the students on our team really understood what FIRST was all about when, two years later, our unofficial team motto changed from "we want to BEAT Chief Delphi" to "we want to BE Chief Delphi." - dlavery [more]
Unread 30-01-2013, 23:43
m5burndt m5burndt is offline
FRC #4256
m5burndt is a jewel in the roughm5burndt is a jewel in the roughm5burndt is a jewel in the roughm5burndt is a jewel in the rough
Team 4256 Shooting Mechanism
I just wanted to share with you some images of our team's shooting mechanism. I've spent a lot of time modelling it and am proud to display the (virtual) fruits of our team's many hours of designing and testing. Enjoy!
Unread 31-01-2013, 00:08
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Re: Team 4256 Shooting Mechanism
We are using a similar design, can i ask what kind of range you are getting?
Unread 31-01-2013, 00:29
FRC #4256
We have yet to test it with a gear-up gearbox. Running a 1:1 (wheel mounted directly to CIM) we are getting aroung 40 ft at a shallow incline (15")
Unread 31-01-2013, 00:41
Kageshini's Avatar
Kageshini Kageshini is offline
AKA: Daniel Joaquin
FRC #3997 (Screaming Chickens)
Team Role: Driver
Kageshini is an unknown quantity at this point
A cim 1:1 might have a lot of speed but not a large amount of torque our team is using a simulator to run our shooter same wheel geared for power and is doing pretty good. Do yall have a tight compression?
Join year 2012
2012 Rookie All Star
2012 Rookie Highest Seed
2013 Alamo Finalist/Wildcard Winners
2013 Newton Semi Finalist
Unread 31-01-2013, 01:01
Chris is me's Avatar
AKA: Pinecone
You don't need much torque for a flywheel, the CIM has more than enough.
Looks great, love the bucket hopper.
Unread 31-01-2013, 01:11
FRC #4256
As chris described, the pneumatic wheel has plenty of mass to result in a big moment of intertia (flywheel effect) as long as it has sufficient rotational energy when the disc contacts it, we are good. The 40' I gave you is a real-life test.
Unread 31-01-2013, 08:16
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
How tight is your compression that you're encountering torque limitations? ...That's a little scary. Are your disks holding up? How did you determine you needed higher torque?
Unread 31-01-2013, 14:13
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
My team is using something very similiar. We really like the radial shooter design.
How do you plan on making the frisbee contact the flywheel? Maybe I'm looking at it wrong but it appears that as soon as the frisbee falls to the bottom of your hopper it contacts the flywheel.
Is there some secondary mechanism that pushes the frisbee into the flywheel? Like an air cylinder or "kicker"?
Anyways looks great!
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
Unread 31-01-2013, 14:34
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Great CAD model. One thing I noticed that I don't like: 80-20. That stuff's very heavy. I would advise replacing those cross-members with angle or something. It would be thinner, MUCH lighter, and just as strong.
Other than that, great design!
Unread 31-01-2013, 23:51
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
I second this.
Also, I love that method of keeping the frisbee in line (that is what the lexan on standoffs is for, right?).
Unread 01-02-2013, 00:09
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
We found in testing that a 1:1 CIM is more than adequate (simpler to implement too!)
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 01-02-2013, 04:59
DavisDad's Avatar
DavisDad DavisDad is offline
MechE
AKA: Craig Rochester
FTC #8470 (Team Technado)
DavisDad will become famous soon enoughDavisDad will become famous soon enough
Originally Posted by m5burndt View Post
I just wanted to share with you some images of our team's shooting mechanism...
Nice work work on the CAD model! Thanks for sharing! Here's a pick-up we're working on. the prototype is working...
Unread 01-02-2013, 09:14
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
That looks like a really neat harvester idea! Looks like it could be quite effective and elegant!
As a recommendation (that I'm sure you've thought of): make sure it's relatively easy for a driver to approach and pick up a disc... as with prior years and game pieces, a harvester's usefulness is often limited by ability to receive a game piece easily. Most often this means making the harvester/mouth as wide as possible...
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 02-02-2013, 00:09
FRC #4256
About the function: The stack of frisbees has a slot cut in the side, when we are ready to fire, an device of some kind pushes/pulls the frisbee into contact with the shooter.
About the 80/20: I agree, its heavy stuff. The thing is we need the adjust-ability because features such as the gearbox and several other points are fixed to 80/20 to allow us precise tuning over the pressure of the wheel-disc-guide dynamic
That said, we are looking at using a lighter material to supply the structure for those members, but attaching very short segments of 80/20 where we need the adjust-ability.
