Go to Post knowing 'my breath stinks' has helped me far more than any thanks and praise I've ever received.. - DonRotolo [more]
Unread 31-01-2013, 00:14
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Need help with which one to use
Could anybody provide any incite on whether I should use an accelerometer or a gyro on my shooter to get the angle that it is currently at.
I have never used either of them that is why I am a little lost.
Any benefits of either one?
Just a little clarification on the photo, it would be mounted on the c channel that is right below our shooters wheel. To sure where on that the c channel or which side but we want to measure the angle of that side c channel.
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 31-01-2013, 00:25
eedoga's Avatar
eedoga eedoga is offline
FRC #2980
eedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud ofeedoga has much to be proud of
Re: Need help with which one to use
I think you should go with a gyro. An accelerometer measures acceleration or change in position, a gyro measures angle. My kids are playing around with using a gyro to help the robot climb up the pole...It isn't going as smoothly as they would like, but I figure it is about the same for both.
Hope this helps.
Edoga
Unread 31-01-2013, 00:31
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
As Edoga said, gyros work better for determining angle. We always use a gyro to run autonomous code so we can drive in straight lines. The same principle applies for a shooter, just on a different axis than the whole robot.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 31-01-2013, 00:40
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Personally, I would use a potentiometer attached to the rotation point of your shooter for better feedback. If you don't have access to one of those, then the gyro would be your best bet. Last time I used a gyro, however, it was quite noisy and you would have to re-zero it several times per match. May be something we were doing wrong though.
I'm right 90% of the time, so why worry about the other 3%?
Unread 31-01-2013, 01:12
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
For stuff like angles I recommend an absolute encoder. They are not that expensive (from a FRC point of view) and, in my experience, easy to use and reliable. The code for an absolute encoder should be easier to write to.
Edit: I remember something about accelerometers and gyros being sensitive to vibrations (like those from a shooter). It's not that the vibrations harm the device, they just make it hard to get any useful output data.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 31-01-2013, 01:28
bhumudar's Avatar
bhumudar bhumudar is offline
Mentor/Programming/Electrical
AKA: Bryant Humud-Arboleda
FRC #0714 (Panthera)
bhumudar is on a distinguished road
I would be inclined to agree with Cecil. Your best option would be to use a potentiometer mounted on the pivot point of your shooter. This method will give you much more useful data, and while it won't give you an explicit angle but rather a voltage reading it is a matter of doing a simple conversion if necessary. My team used it in our last robot, and it worked wonderfully. Since we mounted it on the pivot point the vibration from the shooter barely affected the readings. We used a vex potentiometer, and if price is an issue, they aren't very expensive.
Stevens Institute of Technology
B.A - Electrical Engineering 14'
Mentor - FRC 714 (2012-Present)
Student - FRC 714 (2009-2010)
2013 Bridgewater-Raritan Winners (Thanks 1676 & 3314)
2012 MAR Regional Championship Judges Award
2012 Mount Olive District Excellence in Engineering Award
2012 Chesapeake Regional Finalist (Thanks 2068 & 358)
2012 Hatsboro-Horsham District Gracious Professionalism Award
Unread 31-01-2013, 10:51
AKA: Garty
Arrow Re: Need help with which one to use
Thanks for the helps guys. Is there any examples of how to impliment a potentiometer on it?
- Dr. Seuss
Unread 31-01-2013, 11:05
Cecil's Avatar
AKA: Alex Hummel
That now depends on a few things. First is the design of the shooter. Does the shaft (or other similar pivot point) rotate with the shooter? If not, then is there another rotational point that does?
In the past, my team has used potentiometers similar to these on DigiKey. If you drill out the center of the pivot point and tap a hole for a set screw, it is very easy to grind a flat spot on the potentiometer and hold it in that way. If you go for the Vex potentiometer, you will have to improvise a bit (I have no experience with those).
Programming one is very easy, too. Just wire it into the Analog Breakout in slot 1 of the cRIO to connect it. If you are programming in LabVIEW, you can open an analog input, and get the voltage from it as it spins. From that voltage, you can determine your upper and lower limits, and determine what angle your shooter is at based on those voltages.
Unread 31-01-2013, 11:08
Jared Russell's Avatar
Taking a year (mostly) off
Are you talking about elevation/pitch? Or heading/yaw?
Elevation/pitch is best measured with a sensor like a potentiometer or encoder.
Heading/yaw (of the entire robot) is most easily measured using a gyro (or you can use encoders on either side of the robot to derive angle, but once your wheels slip you are screwed). If your shooter is turreted, a potentiometer or encoder is a great way to measure the relative yaw angle between the shooter and the chassis.
Unread 31-01-2013, 11:18
AKA: Garty
Alright thanks for the info guys!
- Dr. Seuss
Unread 31-01-2013, 11:52
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
For the record, it is actually possible to use a single or dual axis accelerometer to determine the angle of something, since gravity affects accelerometers as much as any other acceleration. Inclinometers are just special purpose accelerometers that give you feedback in degrees relative to level.
So while using a potentiometer is certainly simpler, an accelerometer or inclinometer would give you the angle of your shooter relative to the ground, which is probably what you actually care about for aiming.
Unread 31-01-2013, 12:36
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
We have used a potentiometer for this application with good results. Just be sure you use one that has a linear taper, not an audio taper (logarithmic).
If the shaft rotates with the component just extend the shaft and make connection to the pot. (rubber tubing has been known to work for this.) If not you will have to use a linkage or something that makes something rotate; then attach the pot to that.
Unread 31-01-2013, 14:53
AKA: Garty
Would this one work? http://www.radioshack.com/product/in...Potentiometers
- Dr. Seuss
Unread 31-01-2013, 16:16
Cecil's Avatar
AKA: Alex Hummel
Looks like a perfect one to me. Just be sure that it can support the range of motion appropriately. Some potentiometers only move 3/4 of a turn, and some can turn 10 times before stopping. Know the limits of it, especially before mounting it. You don't want to torque it off.
Unread 31-01-2013, 21:47
AKA: Garty
It has 1080 degrees of rotation. I think we should be good. Went downtown the local RadioShack to pick um up, the guy just gave them to us! Thanks to everyone for the help.
- Dr. Seuss
