Go to Post The GDC needs to write the rules once and let the game be what the game is going to be. There's little that's fun about being told exactly how to play with your toys. - Madison [more]
Unread 21-01-2003, 11:06
angelina angelina is offline
#0900 (TeamSOS)
angelina is an unknown quantity at this point
Question visual signals from operator allowed?
my team is wondering if, during the autonomous 15 seconds, our robot is allowed to recieve visual input (via optical sensor) from the operator area (behind the glass)? I don't know if this is even possible, but our programmers are certainly enjoying thinking about it. Before they pursue it, I want to know if it is legal.
Thanks.
Angelina
Unread 21-01-2003, 12:52
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I suppose you could, though I don't know what input you could give. The range on the optical sensors isn't good enough to do much at the distance you're thinking of, plus, you have glass and diamond plate between you and your robot.
Jeff Waegelin
Unread 21-01-2003, 13:38
D.J. Fluck
Posts: n/a
Jeff is right
This weekend we did optical sensor testing and our sensors had a problem following the line when the tape was ripped. That was only a couple inches off the ground. Im about 90% sure your visual signals will not be accurate. Im on my way over to finish the sensor testing in a few minutes, so ill give that a shot and see what comes out of it
Unread 21-01-2003, 14:11
remember, you can use any sensor from digikey. I think that the question was not whether the optical sensors in the kit are capable of doing this (my answer is probably not) but whether it is legal to make a system that does this (I don't know).
Unread 21-01-2003, 15:13
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
actually, this is very doable. i did some testing with the retroreflective tape and a sensor. i got returns from 20+ feet. sooo, if you mount the sensor on a servo, and make sure the servo is ALWAYS pointed at the operator, you could theoretically give bit input on that.
all in all, it's a very interesting idea. the only major problem is false input. if you accidentally pick up a stack, and make your robot change modes. so, if you're 100% certain you can eliminate false input, i say go for it. otherwise, i wouldnt' take the chance.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 21-01-2003, 15:50
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Per rule 7.3: During the autonomous portion of the game, the robot can only react to programmed commands or sensory inputs on the robot. Operator control is not allowed during the autonomous mode - hence the term "autonomous". Unless I'm misunderstanding what you want to do, you can't send the robot any signals from the control station until after the autonomous period is over.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 21-01-2003, 16:36
D.J. Fluck
Posts: n/a
I did tests today and I lost reading after 10 inches...
It really didnt say in that ruling if that was illegal, but chances are it is. Good question to ask FIRST though...
Unread 21-01-2003, 16:57
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
I read somewhere that you cant have retro-reflective tape on anyone in the players station so what sensor could you possibly use?
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 21-01-2003, 17:44
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
20+ feet or inches??
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 21-01-2003, 18:05
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
You can definately get 20+ feet using the retro-reflective tape. Using a regular mirror or plain white tape is what limits you to a few inches.
Unread 21-01-2003, 18:16
In this case, you are using the sensory inputs on the robot to control the actions of the robot. The question is, what can trigger the sensors on the robot?
Unread 22-01-2003, 13:58
D.J. Fluck
Posts: n/a
I tested with a sheet of paper, white tape (the field line tape) and a kind of reflective tape. All the readings were very similar. Today I am going to conclude my testing and going to test by holding a sheet with reflective tape through the playing field viewing window. Im not expecting much though...
Unread 22-01-2003, 16:39
College? What?
- Katie
easily 20+ feet. i was standing so far away i needed my glasses to see the led on the sensor turn on/off to know i was getting a hit. we probably could've gone a bit farther, but there was a wall in the way .
to make sure you're lining the tape up right, use your face . line your head up, so the red LED (or whatever that thing is) is shining straight into your eyes. then, simply hold the tape up in front of your eyes. sure fire way to make sure you're getting a hit. also, try playing with the sensor settings. i forget what ours was set to, but i'm sure i could replicate it tomorrow if needed.
AIM --> Woloi
Unread 22-01-2003, 17:01
JTH JTH is offline
#1447 (Panther Robotics)
JTH is an unknown quantity at this point
Send a message via AIM to JTH
The optical sensors are capable of sensing retro-reflective tape at about 20 feet per the specs, and our testing agrees with that. We also ran out of room to test. Translucent interferences (such the plexiglass) will obviously reduce that distance.
However, you should also remember this rule.
GM6 Special clothing and/or equipment will only be allowed on the playing field for those who
demonstrate a need based on a physical disability.
I believe that this rule would take out the possibility of using retroreflective tape by the drivers/human players.
Unread 22-01-2003, 20:22
Mike537Strategy Mike537Strategy is offline
#0537 (Charger Robotics)
Mike537Strategy is an unknown quantity at this point
Arggg...our sensors are really sucking. We can barely get even five feet before they stop reacting. Any suggestions?
"Charging into the future, one game at a time." - Team 537 motto
nats: stoping conflicting robot signals? JasonStern Technical Discussion 25 25-05-2003 00:37
Any pratical use for Microsoft Visual Studio .NET Pro Kyle Fenton General Forum 11 28-01-2003 16:59
Referee hand signals archiver 1999 1 23-06-2002 21:57
visual aids for score keeping??? cam-man General Forum 3 24-03-2002 21:37
Visual Game Simulator techknights General Forum 8 22-01-2002 19:43
