Go to Post Why do it the hard way if you don't have too? - ChrisH [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 31-01-2013, 09:19
Vikingtech2054's Avatar
Vikingtech2054 Vikingtech2054 is offline
FRC #5162 (The Big Red Theory)
Vikingtech2054 is an unknown quantity at this point
Re: SolidWorks Weldments
Our team has used solidworks weldments for the last three years, It is a little more difficult to learn, but i feel the bonuses far out weigh the learning curve. Not only on cad is it an accurate way to tell all conflicts.
the drawings for the builders are a lot easier to understand because you can drop a table on there and will tell the builder what parts need to be cut such as length, width, hieght, material, angle cut. Droping many views of the weldment are simple to so the builder can visualize it also. It is easy to customize to fit your needs. I would strongly recommend using it
Ferris State University-Manufacturing Engineering (BS)
FRC 2054: Student 2010-2013
FTC 6283: Mentor 2012-????
FTC 5980: Mentor 2012-????
FTC 7837: Mentor 2013-????
FRC 2054: Mentor 2013-????
FRC 5162: Mentor 2014-????
FRC 5448: Mentor 2016-????
FRC 5576: Mentor 2015
