It really depends on what scaling factor you use in your filter. InnovationFirst has a whitepaper on this, so you can at least find an example there. In theory, experimenting with the coefficient should give you a fairly good reading once you find the ideal settings.
--Rob |
| Usage of the gyro | jon virgi | General Forum | 37 | 09-06-2003 11:57 |
| gyro code | odin892 | Programming | 2 | 08-04-2003 14:50 |
| gyro | odin892 | Programming | 0 | 08-04-2003 09:59 |
| Help with the gyro chip | Team852 | Electrical | 1 | 10-01-2003 22:31 |
| Have YOU used the gyro chip? | FotoPlasma | Technical Discussion | 10 | 31-01-2002 13:26 |
