Go to Post At this rate, Team Update #2 should just eliminate the Minibots and replace it with the drive team captains playing rock-paper-scissors to determine the bonus points. - artdutra04 [more]
Unread 27-02-2012, 22:44
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Waiting to connect to OTA command server
I've searched CD and tried all the things on the other post but we are still getting "waiting to connect to OTA command server" from NetBeans. Here is what we have know and tried:
1) can ping camera, 2CAN, cRio fine
2) reboot the cRio - download again - same issue
3) switched lan cable to wireless (set to 10.33.10.5 / 255.255.255.0) - same issue
4) reflashed the cRio (already had v43, did it again). Downloaded, rebooted cRio - same issue
5) removed 2CAN from network - ping fine - download - same issue
6) connected lan directly to cRio - same issue
7) disable ipv6 - same issue
8) reboot computer - same issue
9) verified windows firewall is off - yes
Any other ideas?
Unread 28-02-2012, 08:29
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Re: Waiting to connect to OTA command server
That sounds pretty thorough :-). Please post the complete output from Netbeans when downloading.
Unread 28-02-2012, 09:17
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
Yeah we've had problems with Netbeans before where it would stop producing output, but the code was still running. I can't really remember, but it might have been right at the point you're describing. It might be just a problem with Netbeans and the code is fine. Post the output so we can see.
FYI our solution to that problem: Eclipse!
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
Unread 28-02-2012, 14:03
Another thing I left off is that I can ftp directly to the cRio fine. Below is the netbeans output.
init:
init:
Deleting directory C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\build
Deleting directory C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\suite
Deleting directory C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\j2meclasses
clean:
Created dir: C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\build
Compiling 48 source files to C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\build
compile:
Created dir: C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\j2meclasses
preverify:
Created dir: C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\suite
Building jar: C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\suite\Team3310FRC2012_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 285 classes and generated 4 files.
Expanding: C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\suite\Team3310FRC2012_1.0.0.jar into C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\suite
Moving 1 file to C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\suite
Deleting: C:\Users\bselle\Documents\NetBeansProjects\Team331 0FRC2012\image.suite.api
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) 64-Bit Server VM 19.1-b02
Target IP: 10.33.10.2
Network interfaces on host:
Intel(R) Centrino(R) Ultimate-N 6300 AGN: address: 10.16.25.170 netmask: 255.255.255.255 or hidden by IPv6 address (due to Java on Windows Bug:6707289)
Intel(R) 82577LM Gigabit Network Connection: address: 10.33.10.5 netmask: 255.255.255.0 <--- on robot's subnet
Connecting FTP @10.33.10.2
upgrade:
Sending local file image.suite
flashapp:
deploy:
init:
Waiting to connect to OTA command server of 10.33.10.2:8001 for past 11s
Waiting to connect to OTA command server of 10.33.10.2:8001 for past 12s
Waiting to connect to OTA command server of 10.33.10.2:8001 for past 13s
Waiting to connect to OTA command server of 10.33.10.2:8001 for past 14s
Waiting to connect to OTA command server of 10.33.10.2:8001 for past 15s
Waiting to connect to OTA command server of 10.33.10.2:8001 for past 16s
Waiting to connect to OTA command server of 10.33.10.2:8001 for past 17s
Waiting to connect to OTA command server of 10.33.10.2:8001 for past 18s
Waiting to connect to OTA command server of 10.33.10.2:8001 for past 19s
Waiting to connect to OTA command server of 10.33.10.2:8001 for past 20s
Unread 28-02-2012, 15:24
Finally got it work. Previously when I reflashed the cRio I didn't check the format box. I did it again with the format box checked and it worked (after the reboot issue).
Thanks for your responses!
Unread 28-02-2012, 16:42
dbeckwith's Avatar
Lead Programmer
Glad you fixed it, because that wasn't the issue I had in mind.
q = (2*b) | ~(2*b);
Unread 31-01-2013, 10:28
hdodge2972 hdodge2972 is offline
FRC #2972
hdodge2972 is an unknown quantity at this point
I am having the same issue with out new cRIO ii trying to download code from netbeans. I have tried everything that you guys have. Exact same error except with team 2972 credentials. Any ideas?
Unread 31-01-2013, 17:41
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Try rebooting the cRIO multiple times, it always seems like you have to reboot it once after imaging it, and a second time after trying to send code for the first time. At least from personal experience.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 31-01-2013, 20:10
jesusrambo jesusrambo is offline
Self-Proclaimed Programmer Messiah
AKA: JD Russo
FRC #2035 (Robo Rockin' Bots)
jesusrambo is an unknown quantity at this point
Yep, I've noticed that for the past four years it's been like that. Every time I reimage the cRIO and deploy code, it'll stick on that and I have to manually reboot.
