Go to Post I guess this means we have to work on becoming super-flexible and always be ready for our close-ups at robotics from now on? - Beth Sweet [more]
Unread 31-01-2013, 09:45
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
Saving Value to the cRIO
Does anyone know how to save tuning values on the cRIO and be able to to update the variables without re-flashing the software? We are wanting to do this so that we can calibrate the robot easily at the competition.
Unread 31-01-2013, 10:37
Re: Saving Value to the cRIO
Here's only one example of creating and saving a text file on the cRIO from your cRIO program.
You can create and save other types of files, too, that might be more appropriate for your calibration data.
Look under Programming -> File I/O for these and how to read the data back in.
Name:	Save a file.png
Unread 31-01-2013, 11:08
Bpk9p4's Avatar
FRC #1756
so can you send values from the drives station to the cRIO and have it be saved there? Also with this method you have to reflash the software each time you send a new text file?
Unread 31-01-2013, 11:25
You save whatever values you want, from wherever they came.
If you are instead talking about creating a File locally on a PC, then ftp'ing the File to the cRIO, that's a different thing, but also possible. You have to handle the ftp part yourself.
Just write your cRIO code to read the local File on command.
