Go to Post ... if there is no standard against which you determine success, then you can never fail. - dlavery [more]
Unread 31-01-2013, 10:51
Re: Velocity PID Programming: Terms dependent on time
Originally Posted by Tom Line View Post
Anyone know if there is a common high-resolution timer that can be called from LabVIEW? I'm only familiar with the millisecond resolution timer that's available from the timing palette.
Most graphical languages have built-in support for C. Perhaps a LabVIEW guru could post a simple example how to call the 3 timers kenfox listed.
