#10
Re: CIM Motor Burn Out Question
The CIM does not depend on air cooling. They are pretty tough to burn out. I very much doubt if there will be a problem.
To connect to the CIM get some hubs from Andy Mark. They have some that are specifically intended to mount any of their wheels to a CIM, 8mm shaft diameter as I remember. If you want to support the shaft above the wheel also just attach another hub and attach a short shaft into a bearing. |
