Go to Post I also believe that any team in the finals or any 200 scores will be big. - henryBsick [more]
Unread 31-01-2013, 00:00
ENeyman's Avatar
ENeyman ENeyman is offline
AKA: Emmett Neyman
FRC #3929 (Atomic Dragons)
ENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant futureENeyman has a brilliant future
Re: 3 Wheel 3 CIM shooter
Originally Posted by Jeffy View Post
In this video, you will notice the Frisbee flies out of the shooter at an angle. I have seen this happening in videos, but it wasn't noticeable in our prototype. While it may not be an issue for most, it can make scoring a bit tougher.
When you find a way to solve the issue (which I think you will), I'm sure I wouldn't be the only one eagerly awaiting to know what causes the "off angle" exits of Frisbee. Much appreciated if you don't mind.
I believe the spin comes from only one side of the disc being spun. Because the force is exerted on the right side of the disc, the frisbee will curve slightly to the left. That's just my theory.
Mid-Atlantic Regional Championships (2012)- Rookie All-Star Award
World Championships (2012)- Rookie Inspiration Award
Chestnut Hill District, Mt. Olive District (2013)- Entrepreneurship Award
Lenape District (2014)- Winner
frc3929.org
Unread 31-01-2013, 00:32
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
And I thought 2 miniCIMs for a shooter was crazy. I look forward to seeing this launch some disks!
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 31-01-2013, 01:02
Chris is me's Avatar
AKA: Pinecone
Have you guys directly compared this to a 2 wheel, 2 minicim shooter? I am really curious how much more distance and repeatability you get.
Unread 31-01-2013, 02:23
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I actually intended to describe the frisbee coming out of the shooter not level with the base. The curve is a direct result of an un-level frisbee.
I thought about it further and think it may be a function of the stored energy in the pneumatic wheel compression. The compression coupled with the wheel deforming to "cup" the frisbee gives a reaction where the frisbee comes out non-level with the launch base.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 31-01-2013, 11:24
I recall seeing another thread a while back where a team had a similar issue and found the cause: the frisbee was slightly climbing up the wall of the guiderail -- it was not staying flat on the base. Can you take some video with a camera angle looking "down the barrel of the gun" - you might be able to see this effect.
If that's what's happening in your case, you might be able to solve it by tilting the guiderail slightly toward the frisbee, or adding a piece to keep the frisbee from climbing the guiderail.
Unread 31-01-2013, 12:49
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Have you given much thought to incrimentally increasing the speed of each subsequent wheel?
In other words, why directly drive all three wheels? A lot of teams have shown significant success with (relatively) lower speeds on the first wheel the disc comes in contact with. Additionally, it should (theoretically) increase your throughput (and potentially overall efficiency), as the first wheel will lose less energy and thus return to effective speed quicker.
Unread 31-01-2013, 20:00
TheCrayButton's Avatar
TheCrayButton TheCrayButton is offline
FRC #3528
TheCrayButton has a spectacular aura aboutTheCrayButton has a spectacular aura about
WOW! Very impressive you guys. That is getting some distance. Do you all plan to shoot full court?!
Unread 01-02-2013, 01:12
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
The day before we had CIM > Mini > wall and it was hitting 9 feet up at about 40 feet away, this is at least double that with the extra mini
This is doing that to an extent as the first wheel it contacts is going 5,300 RPM and the next 2 are going 6,200, We enjoy not having to worry about chain or gearboxes and seeing as we are getting more than full court shots (with amazing accuracy, hitting the same cinder block on the wall 3 times in a row from 70 feet) this is the design we are going to go with.
Thanks! It looks like that's the plan after today's tests, you will see one of them in our Vlog this week, I think they forgot what years game they were playing if you know what I mean
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 01-02-2013, 09:33
Racer26 Racer26 is offline
You know you don't *have* to do this with gearing, right? Those motors are on speed controllers, so you can simply experiment with the speed values you send them once you have a proper control system in place. Many teams have reported great success with 2xCIM linear shooters, direct drive to the wheels, with the first one set about 60% speed.
Unread 01-02-2013, 10:27
AKA: Pinecone
Good to know. We tried mini -> mini a while back and got results that were good enough to move forward. I'll see if I can't leave space in the design for a third motor just in case we end up feeding or something.
