Go to Post guarantees don't mean anything when you're dealing with FRC good sir ;) - Zuelu562 [more]
Unread 31-01-2013, 17:06
akash992391 akash992391 is offline
AKA: Akash
FRC #4684
akash992391 is on a distinguished road
Problem with cRIO Imaging tool
hey guys
i dont know wat exactly happen but there is a message says that "unable to assign an IP address for the CompactRIO device.Ensure the IP Reset switch on the compactRIO device is turn off."i have no idea wat to do can u please help me please...... thanx
Unread 31-01-2013, 17:15
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: Problem with cRIO Imaging tool
On the cRIO by where the power is connected there are white switches that can be toggled like a teeter-totter back and forth. Turn your cRIO off and then toggle the one that says IP Reset next to it to the on position. Turn your cRIO back on and the indicator light should flash yellow until the IP is reset. Once it's done flip the switch back to off and attempt to image the cRIO again.
Edit: I believe the switches are called "DIP Switches"
Edit: It sounds as if the DIP switch for the IP Reset is in the on position, all DIP Switches should be off when imaging a cRIO and for normal operation.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 31-01-2013, 17:26
AKA: Akash
FRC #4684
but we have the 2013 version one there is no white toggle swithches....
Unread 31-01-2013, 17:30
AKA: Spencer Lanman
In that case the DIP switches are virtual and can be toggled within the cRIO imaging tool.
Resource: http://wpilib.screenstepslive.com/s/...ging-your-crio
Shooter Operator
Catapult Operator
Chainsaw Operator
Unread 31-01-2013, 22:22
The typical troubleshooting steps for this sort of problem:
Turn off the Windows firewall.
Double-check that your wired Ethernet connection is configured with the proper IP address (in your case, 10.46.84.5 or .6) and only that address. Then check it again. Then have someone else check too.
Make sure that all other network adapters are disabled.
