Re: Belt pulley options
What do you use to tension your belts?
Proper center-to-center distance.
Do belts stretch like chains do?
I think some cars have idler pulleys to keep the belts under the correct tension. It would be nice (and lighter) if idler/tension pulleys were not needed. |
These belts have a fiberglass cord backing so in FRC usage they don't have a big problem stretching. We add .005 - .003 inches to the C-C distance given by the calculator and have no had any issues.
How do you determine this? I used the online calculator from SDP-SI for some XL belts and pulleys from McMaster, and when they showed up it was way off. So, I'm just going with holding the actual setup tight and measuring it out. Does this sound like a plan?
Could you have had an inches metric conversion error? Or an mis ordered part? |
#7
I've used the SDP calculator for multiple projects as well, FRC and others, and it's never led me wrong. I'd suspect something else happened there.
-Mike |
#8
If you're planning to spin a shooter wheel at high speed I'd suggest urethane belting instead of a toothed belt.
