Go to Post Every time i look at my watch and see 3:65 o'clock I always thing, darn i gotta get a new watch... - Kyle [more]
Unread 31-01-2013, 17:44
CauseImAzn CauseImAzn is offline
FRC #4500
CauseImAzn is an unknown quantity at this point
Lighting Camera M1011
What do your teams use for lighting the retroactive tape for the cameras. My team was thinking of using angel lights: http://www.superbrightleds.com/morei...ent-lights/49/
Any input would appreciated!
Unread 31-01-2013, 19:51
tophkissane tophkissane is offline
FRC #1493
tophkissane is an unknown quantity at this point
Re: Lighting Camera M1011
In the past we have used the green led rings from andy mark. these look very comparable so they should do the trick. however I don't know if they need to be in a certain color or if it makes things easier because we have always used the green
Unread 31-01-2013, 20:56
mgerber's Avatar
mgerber mgerber is offline
Shoddy Programmer
AKA: Max Gerber
FRC #0223 (Xtreme Heat)
mgerber is on a distinguished road
We have used those in the past with very good results, and plan on reusing them next year. They work like a charm- bright, easy to control, cheap, and quick to set up. My favorite aspect of ring shaped LEDs is that they nest inside each other, which makes it very easy to add on another layer while still keeping the camera in the center.
As for color, I'd think that you'd want to go with something that isn't going to be the same as any background lighting. Green works well, when we played around with our camera settings we were able to get an image that saw most artificial light as orange or red, while the target remained bright green. That makes for much better vision processing.
Unread 31-01-2013, 21:41
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
They don't just look comparable; SuperBrightLEDs is the manufacturer of the ones that AndyMark distributes.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
