Go to Post I've come to the conclusion that the only way Pat's awesomeness can be explained is.... Pat Fairbank is a cookie. - Jonathan Norris [more]
Unread 31-01-2013, 19:11
derekogle37 derekogle37 is offline
FRC #4512
derekogle37 is an unknown quantity at this point
PWM Not going to full on
So I'm using the the set function of the victor class to control a motor, when I pass -1 to the function, the motor goes in full reverse no problem and the victor indicator light goes red. But when I pass 1 as the parameter the motor goes to full speed (or what appears to be), but the green light will not come on on the victor. I've tried putting in a larger value such as 3 or 4 and even 255 but it will not accelerate further nor will the green light come on. To confirm that it was not the controller I switched back to using the robotdrive class with the tankdrive function, and it had no problem going full forward with the green indicator light coming on. I also tried a few different controllers and PWM ports with the same results.
Basically my code is
//Definition section
Victor* motorlaunch;
//Constructor section
motorlaunch = new Victor(1,3);
//Teleop section
motorlaunch->Set(1);
Unread 31-01-2013, 19:15
Re: PWM Not going to full on
Try calibrating that Victor.
Unread 31-01-2013, 19:17
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Full support of this action. (Y)
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 01-02-2013, 09:45
FRC #4512
Worked perfectly, thanks a lot!
