Go to Post Nothing's more memorable than giving someone a foul mouthed clown :cool: - Dave Scheck [more]
Unread 31-01-2013, 19:06
Jay Meldrum's Avatar
Jay Meldrum Jay Meldrum is offline
FRC #0067 (H.O.T.)
Jay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud ofJay Meldrum has much to be proud of
PIDController with Potentiometer
Our students are currently trying to reprogram last years robot with Command based programming. Last year we used a homemade PID function to controller our arm instead of wpi's PIDController.
We are now trying to use PIDController with the arm; one potentiometer is the input. When we set the set point to a known location and enable the PID, the pid outputs -1 100% of the time, when we move the arm across the known point the pid output never changes. Below is how we have the ReturnPIDInput defined.
We have had success with controlling the Shooter with a PID but we cannot get the arm to work.
Is it possible the PIDController is trying to read a voltage too quickly from the pot and we are recieving a NULL value back?
Anyone run into issues with this?
double Arm::ReturnPIDInput () {
	return armPot->GetAverageVoltage();
2012-2015 - FRC 67 - Programming/Controls Lead Mentor
2003-2005 - FRC 857 - Driver
Check us out at http://www.hotteam67.org
Previous year design docs, programming tutorials, and more!
Unread 31-01-2013, 19:19
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Team3266Spencer is an unknown quantity at this point
Re: PIDController with Potentiometer
Have you tuned the PID values?
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
what is happening to the signal from the pot when you are doing this?
Unread 31-01-2013, 19:27
FRC #0067 (H.O.T.)
When we read directly armPot->GetAverageVoltage(); we get expected values that range from 0 - 3.
However we believe the PIDController is not receiving that value.
We are using PID values from our previous PID loop, but we are not even trying to power the motors in this debug stage.
If we manually move the arm across the setpoint we should at least expect a change from the output of the PID to go from a negitive number to a positive number or vise versa. We currently do not see that.
Unread 31-01-2013, 19:46
Why the uncertainty? Is there no way to examine that?
Unread 31-01-2013, 22:47
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
Try reading armPot->PIDGet(). This should show you exactly what values the PIDController class is getting.
Proud alum of CORE 2062.
www.core2062.com
Unread 03-02-2013, 10:49
FRC #0067 (H.O.T.)
Thanks nightpool. Interesting results. When reading armPot->GetAverageVoltage() we receive values that range from 0-3. (armPot->GetAverageVoltage() is what we return as the input to the PID loop). However when we read armPot->PIDGet() we receive values from 300 to 600. When we change our set points to match what PIDGet is receiving the PID works as expected... Not sure what is going on here, but at least we have a solution.
Thanks again
Unread 04-02-2013, 18:24
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
I think the PIDController is getting integer counts ranging from 0-1024.
Interestingly, we've been using the HOT_PID controller for years, starting in 2010. Now, we are doing exactly the same thing this year, switching over to commands and WPI PIDController.
This was confusing to us as well when we switched over. Try reading armPot->GetAverageValue. That should give you the same value as the PIDGet function.
Just give it an integer value in the 0-1024 range instead of the 0-5V range, and you should be good.
And thanks for the years of use from the HOT_PID.
Unread 05-02-2013, 10:20
FRC #0067 (H.O.T.)
Thanks Jeff, we'll be sure to try the GetAverageValue function with setting the range differently. Glad HOTPID helped you throughout the years. We are sad to not use it anymore as well, but when PIDController works, it works great.
Unread 06-02-2013, 16:29
AKA: Brad
#0190 ( Gompei and the Herd)
That has been a little confusing.
The hardware returns a value between 0 and 1023 for 0-5V. The library will return either the hardware value or the voltage and it's important to be consistant in your units otherwise the output values will be way off.
Brad
Brad Miller
Robotics Resource Center
