Go to Post [You know you've overdoes on FIRST when...] You're willing to take an 8 AM for the team. - ttldomination [more]
Unread 31-01-2013, 19:00
xraymypanda's Avatar
xraymypanda xraymypanda is offline
Cowboy programmer
AKA: Chris M
FRC #0599 (RoboDox)
xraymypanda has a spectacular aura aboutxraymypanda has a spectacular aura about
Driver Station loads an old SmartDashboard
I've updated the Smart Dashboard on the computer I'm using. When I open the Driver Station it loads an old version or incompatible version of the SmartDashboard that does not have a camera module in it. I've already quadruple checked the cmd-line path to make sure it points to the correct file. Is this just a weird bug or is there something I can do about it?
2011: Head Scout
2012: (figure)Head Programmer
2013: Head Programmer, Chief Strategist, Outreach Executive, and Driver
Unread 31-01-2013, 19:05
Re: Driver Station loads an old SmartDashboard
I assume you've manually run the Smartdashbard that you set the DashboardCmdLine to and it works?
The DashboardCmdLine is only used if the the dashboard setting in the setup tab is set to Default. If you've set it to C++ (or Java), it will run the SmartDashboard that was installed with the language update, which doesn't have the camera extension.
Unread 31-01-2013, 19:33
Cowboy programmer
AKA: Chris M
FRC #0599 (RoboDox)
You are correct. Switching to Default worked for me. Thank you.
2011: Head Scout
