Go to Post Anything is capable of happening in FIRST. - Dorienne [more]
Unread 21-01-2003, 19:17
yangotang's Avatar
yangotang yangotang is offline
#0253 (MRT)
yangotang is on a distinguished road
Send a message via AIM to yangotang
How long is one stamp loop
What's the time (in milliseconds) to go through one loop?
Unread 21-01-2003, 19:23
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
http://www.chiefdelphi.com/forums/sh...717#post122306
Unread 21-01-2003, 19:26
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
I really can't tell you. One loop through the code is at minimum 26ms. What it is for you is different. Any change to your code will lenghten or make your loop time smaller. If you are trying to make a timer then check here.
Hope this helps.
[edit]
Sorry. The other post wasn't here when I went to reply[/edit]
Unread 23-01-2003, 20:36
Cipher X's Avatar
Cipher X Cipher X is offline
no team (Former SigmaC@t Member)
Cipher X is an unknown quantity at this point
Send a message via AIM to Cipher X
Stamp BS2 * Timings
http://www.emesystems.com/BS2speed.htm
That site lists the timing of the commands in pbasic for each chip.
The stamp inside the innovation FIRST controller is a STAMP BS2SX
so you can find the timings for that at that page. The "Homepage" http://www.emesystems.com/BS2index.htm has some info that might be useful but its really geared towards ppl that buy the actual stamp and prototype with it.
I hope the page was helpful
"Whatever you do will be insignificant, but it is very important that you do it."
-Mahatma Gandhi
Threads getting too long to make sense of Ken Leung CD Forum Support 22 05-05-2005 01:14
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
How long should production time be??? archiver 1999 4 23-06-2002 23:16
