MARS 2614's Practice Robot Nearing Completion!
Since 2011, MARS has built its practice "beta" robot slightly ahead of schedule of the construction of its competition "alpha" robot (allowing us to identify issues and fix them before construction the alpha robot). This year's beta robot is taking shape and is (almost) ready for a weekend of testing and improvement!
https://www.facebook.com/photo.php?f...type=3&theater https://www.facebook.com/photo.php?f...type=3&theater https://www.facebook.com/photo.php?f...type=3&theater Some Details: -Dropped center 6WD, 2-speed transmission geared for 5ft/s and 17ft/s. -2 wheel linear shooter. -360 degree rotating and tilting turret. -Load disks from feeder station, YES. -Floor pickup, YES. -Fit under pyramid, YES. -Level 1 hang, YES. -Level 2 hang, HOPEFULLY (it's designed but we won't know for sure until we do some more testing ).Good luck to everyone!! |
Re: MARS 2614's Practice Robot Nearing Completion!
I'm digging the colsons. Looks like some of the northeast teams rubbed off on you.
![]() Stoked to see video of this soon, looks to be another effective design from MARS. |
Are those 8 inch Colson's? O.O
This is a very pretty bot, though I still don't see the frisbee pickup or shooter. I guess that's all in construction? Can't wait to see it run! |
Correct, the shooter transmission and wheels are not yet mounted and neither is poly cord or the front part of the floor capture device which makes it kind of hard to see those subsystems in the picture. You can see them in the CAD though (you might have to squint to see the shooter wheels hiding behind the shooter rails in the CAD ) |
Looks great!
It's a bit hard to tell, but it doesn't look like there's enough space for four frisbees in the ground pickup. Is there some way that frisbees are fed back into the human load chute on top? |
Well, we have to leave something to mystery. We can pick up four frisbees
#7
The turret tips down and the frisbee is put into the same chute that it will fly out of?
#8
The intake is interesting, because it appears that frisbees would slide onto that plate for a few inches before contacting the roller. Can you provide any details regarding the wheel mounted between the shooter and the frisbee hopper? Could this be part of your level 2 hanging mechanism? |
#9
I believe you are seeing the wheels which help feed the Frisbees down from the hopper into the shooter (similar to the wheels on Robot in 3 Days). |
#10
I just love that time of year when I get to see what cool designs other people have been working on...
I was especially excited to see the intake. Besides the obvious (climbing), pickup of frisbees is the most chalenging part of the game. It looks like you've found a solution that works for you, we just never found a way to pick up frisbees that was satisfactory fo us. Good luck with your season! |
#11
Looks fantastic. I was especially taken with the idea of using the shooter elevation actuator as your level 1 tower lift.
#12
Update:
This past week was mostly spent working out kinks and bugs, iterating some designs, and implementing those changes as the the alpha robot went into production. (Apologies for the poor video quality) Loading the shooter via a full magazine was tested (although the code for the fully automated sequence is not yet complete). https://www.facebook.com/photo.php?v=564421343568944 The first successful level 1 hang was completed (it is fully off the ground in this video but we are missing a disproportionate amount of weight in the front so in the final iteration the hang will be much more balanced). https://www.facebook.com/photo.php?v=564414033569675 The latest iteration of the floor grabber was tested (we understand what changes we have to make to get the Frisbee to more reliably travel up the rest of the feed system). https://www.facebook.com/photo.php?v=564439130233832 The alpha frame is back from being powder coated and was stuffed with electronics last night. https://www.facebook.com/photo.php?f...type=3&theater And here is a slightly updated CAD render (the biggest difference is the new level 1 hook design) https://www.facebook.com/photo.php?f...type=3&theater We have also tested feeding the Frisbees backward through the shooter and into the breech and of course the pan and tilt functionality of the turret has been tested (sorry, no video at the moment but I'll try to get that up over the weekend). Additionally, excellent progress is being made on the level 2 stage of our hanging mechanism. Good luck to everyone!! |
#13
That floor intake is very similar to ours. I have a quick question though. What we're finding is that with our system, an upward force is placed on our intake system when the frisbees attempt to enter and angle upwards in the intake system. How are you guys absorbing that force?
(The idea behind the force from what I understand is that the frisbee is not compressible, and you can only rely on friction to bring it in. ) |
#14
The upper roller on our system is pretty robust, so even if the frisbee forces it upwards, and off the floor, it doesn't bend. The shallower the angle, the better of course.
#15
I can't wait to see you guys at Pittsburgh! |
