Go to Post You definitely know you've overdosed on first when you wash the aluminum shavings off your hands AFTER you eat dinner. - Maxpower57 [more]
Unread 31-01-2013, 21:55
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: Extending a Hex Shaft?
Originally Posted by craigboez View Post
You can always throw away the shaft that came with the gearbox and make you own longer shaft out of some hex stock. We have done this a few times with planetary gearboxes. It will probably involve turning one end round, adding a snap ring groove, and milling some flats. This is very doable with a manual mill and lathe.
Originally Posted by AllenGregoryIV View Post
Any suggestions for teams without a lathe or a mill?
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
