Go to Post That's not duct tape as adhesive, it's duct tape as decoration! :p - Don Knight [more]
Unread 01-02-2013, 00:04
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Re: MARS 2614's Practice Robot Nearing Completion!
Originally Posted by Garten Haeska View Post
The turret tips down and the frisbee is put into the same chute that it will fly out of?
I agree with this. It appears that the turret would turn 180 degrees from its position in the CAD render and then would tip to allow frisbees to directly enter the shooter barrel from the intake. I am still puzzled as to how it can hold 4 frisbees between the intake and the shooter.
The intake is interesting, because it appears that frisbees would slide onto that plate for a few inches before contacting the roller.
Can you provide any details regarding the wheel mounted between the shooter and the frisbee hopper? Could this be part of your level 2 hanging mechanism?
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
